Engine Code Location - NewBeetle.org Forums
Old 02-24-2009, 12:00 PM
Default Engine Code Location
Where can I find the engine code on a 2002 Beetle? I have looked but I can not find it. It is either engine code AZG or AEG. Or does it matter what the engine code is when you are getting parts,,,i.e.,, oxygen sensors, spark plugs, etc....
Thanks
Frank
Old 02-24-2009, 03:39 PM
Car: 2001 GLX 1.8 Turbo - TechnoBlue
Not sure where it is on the Engine, but I found mine on the Build sticker back by the spare tire.
Old 02-24-2009, 04:24 PM
kaiser's Avatar
no longer use this site
torrington, CT, USA
Car: 01 techno blue t3/t4 big turbo
there is a sticker on the timing belt cover, it has a barcode on it and some other info, the code is on there too.
or you can pm me your vin and i can run it to see what it is.
i didn't think azg's were a us motor. i was under the impression that the avh came after the aeg.
sold the beetle, don't use the site anymore
Old 02-25-2009, 12:26 AM
Found the code today. Removed the motor cover and the sticker was on the timing belt cover. It is a AZG motor.
Thanks all for the help.
Frank
Old 03-06-2009, 01:48 AM
JLasvegas's Avatar
Las vegas, NV,
Car: 2002 black 2.0 5 speed
Frank
whats the difference between the 2?
engine code location milton 1.8 Liter Turbo 1 10-09-2008 10:09 PM
Engine Termp Sensor Location? Audiophil 1.8 Liter Turbo 5 12-15-2006 02:44 AM
HELP!!!!!! what engine code? Nb2Nv 1.8 Liter Turbo 8 11-20-2006 06:11 PM
AWV = What engine code??? Photo 1.8 Liter Turbo 9 05-30-2006 08:42 PM
where is a good ground location in engine bay? ninsei 1.8 Liter Turbo 4 01-10-2006 06:12 PM
