Passenger Wheel Problem? - NewBeetle.org Forums
Old 02-28-2009, 09:18 PM
Default Passenger Wheel Problem?
Last summer my wife was side swipe by a drunk driver at a fairly low speed less than 25 mph.
She was struck on the passenger side, from the back of the door to the back of the front bumper cover, he also hit the front wheel as the rim had a small dent in the edge and knocking it out of balance.
NOw my problem is this, the passenger side Wheel is tilted inward at the top by a couple of degrees, visible to the eye, you can tell its not right.
Now, I've had the wheel off and looked at all the parts and there doesn't seem to be, to my untrained eye, anything out of place or bent, but obviously something isn't right.
I was hoping you guys might be able to give me some ideas as to what might be bad? or could an alignment take care of this?
I've included a pic below that I've cropped to show how the tire looks on the car. If I can dig up my Camera I'll get an actual pic.
Thanks In advance
any help would be appreciated.
Old 03-01-2009, 12:49 AM
LadybugEwa's Avatar
PUNCHED BUG
Toronto, Ontario, Canada
Looks very similar to what mine looked like after my accident, only I was hit on the back wheel. My whole rear axle had to be changed.
The important thing is, that we weren't able to pinpoint where it was bent until we disassembled that side down to the bare axle.
Looking at the pic, there's something seriously bent in the suspension. The car is most certainly not safe to be driven like that. There's a chance of damage to the brake caliper and disc. The angle you're seeing could be a bent control arm. Or stub axle, but these are stronger. Maybe damage to the ball joint as well. This needs a mechanic who knows suspension, and it won't likely be cheap. Good luck
Here's a look at Ladybug
Old 03-01-2009, 01:31 AM
vw87tech's Avatar
vw guy
sayville, NY, USA
Car: 98 new bug 68 squareback 03 GLI
the whole strut could be bent
Long Island Volkswagen Club--www.livc.net
Where AIR and WATER Unite
Old 03-01-2009, 05:46 AM
Deserion's Avatar
Moddin' Lion
Jacksonville, FL, USA
Car: '95 E320, '04 986
There is a multitude of points it could be. Could just need an alignment, but maybe not.
Could be the lower control arm, could be the hub, the steering knuckle, etc etc. Take it to a shop for inspection - if parts are needed, then contact your insurance agent to inform them additional repairs are required to get the car back to proper.
Previously:
Old 03-01-2009, 02:08 PM
Thanks for the replies guys, I appreciate it.
Both Driver and Passenger Window Problem - Arrghh! 5t3v3 Questions, Issues, Concerns, or Problems with the New Beetle 2 02-25-2008 10:06 PM
passenger window problem shellbug New Beetle Convertible 6 05-30-2006 09:55 PM
Help: Problem with my drivers passenger window? NemoBug Questions, Issues, Concerns, or Problems with the New Beetle 3 05-05-2006 04:13 PM
Unknown problem under driver's side front wheel.. help! pinktimbs 2.0 Liter Gas 7 04-04-2006 11:11 PM
how do i tell if my beetle is front wheel drive, back wheel, or 4 wheel? crazi_daisy Miscellaneous Hoo-Ha Archive 6 01-02-2006 09:44 AM
