Test a convenience control module? - NewBeetle.org Forums
Old 03-01-2009, 09:13 PM
Default Test a convenience control module?
Does anyone know how you might test a convenience control module?
I have no power windows working, sunroof doesn't work, the doors don't lock or unlock by remote and the rear hatch "posp" as if it's trying to open itself.
I've checked fuses and can't find one for any of these things. I have found a 30 amp in the area below the CCM, but it tests sat.
Old 03-01-2009, 09:14 PM
Forgot to mention. I have a 2000 Beetle.
Old 03-01-2009, 09:34 PM
More info.
I recently had a good samaritan clear an airbag code ( I had removed a seat).
This is what the VAG-COM said about the "Central Conv" which I take to mean the Convenience Control Module.
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
No fault code found.
Any thoughts?
Old 03-01-2009, 09:41 PM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
Originally Posted by joeb1kinobe View Post
More info.
Coding: 00256
Shop #: WSC 00066
Any thoughts?
It's not a Central Convenience Module, that's just a group that the VAG-COM reads from directly in the ECU. Was this person by chance using a PAID-FOR version of the Ross Tech software? If not, the airbag control unit (which is an actual separate piece from the ECU will have to be replaced.
More info:
http://www.ross-tech.com/vag-com/vw_issues.html#Airbags
2004 Ford Focus ZX3
Drive more, worry less.
Old 03-01-2009, 09:53 PM
Yes, this person was using a paid for version of the Ross Tech software.
What are your thoughts on what I should look for to solve my problem?
Old 03-01-2009, 10:44 PM
FarrisK's Avatar
I would check the wiring in the driver door panel. Everything (except the sunroof) that you're talking about goes through there.
convenience module??? petes 1.8 Liter Turbo 6 03-09-2009 03:58 PM
WTB Convenience Control Module joeb1kinobe Parts and Accessories 0 02-25-2009 12:05 AM
Fan Control Module FCM lunchindabox Market Place Archives 3 01-18-2008 04:09 PM
convenience control unit/module carlieabbott1 2.0 Liter Gas 4 09-19-2007 10:28 PM
Fan Control Module C89ZX7R Questions, Issues, Concerns, or Problems with the New Beetle 1 12-28-2005 08:28 AM
