p1296 code - cooling malfunction - NewBeetle.org Forums
Old 03-03-2009, 03:34 PM
mrsbeazley's Avatar
riverside ri , RI, USA
Car: 2002 beetle 2.0 gls
Default p1296 code - cooling malfunction
my bug will on / off throw this code . it there a sensor i should replace or flush the radiator . no lights ever come on except for the check eng. light
my bra must fit correctly or my headlights will look bad .... beazley
Old 03-03-2009, 05:07 PM
Ramsey, NJ, USA
Car: 01 New Beetle 2.0 Gas Auto
Default P1296 Code issues solutions
Hello:
I saw these solutions in posts here.
http://www.newbeetle.org/forums/showthread.php?t=3937
Here's another.
http://www.newbeetle.org/forums/showthread.php?t=34104
Though it could be many specific things.
The P1296 code is cooling system. Good Luck
Old 03-04-2009, 02:58 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
There is at least one more:
P1296 Code and lessons learned
It is probably your thermostat or coolant temp sensor. Doubtful if the radiator has anything to do with it; this fault, I believe, is usually the result of the engine not warming up fast enough to suit the ECM.
Old 03-04-2009, 11:31 AM
mrsbeazley's Avatar
thanks ill check them out
A p1296 GoRoush Questions, Issues, Concerns, or Problems with the New Beetle 1 02-15-2009 12:57 PM
P1296 Code and lessons learned cep 2.0 Liter Gas 6 12-29-2008 04:07 AM
P1296 CEL Code sneidy Questions, Issues, Concerns, or Problems with the New Beetle 6 02-12-2008 02:01 AM
Cel Code P1296 silvertech 2.0 Liter Gas 3 11-25-2006 09:26 PM
Help with CEL Code P0118 and P1296 eno 2.0 Liter Gas 1 07-31-2006 04:04 AM
