Hi
We did our first belt replacement at around 80K and are getting ready for the second replacement. I do not recall any special tools needed. Is there one?? Someone referred to this tool. http://www.ecstuning.com/stage/image...2/600/8162.jpg Will this be needed to make life easier? Thanks Dan Last edited by dgrant09; 03-06-2009 at 01:41 AM.. |
linky no workie.
but if you are changing the belt, be sure you get their deluxe kit with all the bolts in it. the only really special tool required is for the tensioner. I assume you have a large floor jack to use to support the motor when the mount is out. the tool is a two pin wrench that can be made easily or substituted easily with some 90 degree needle nose pliers or a s simple as a bent fork if you are REALLY cheap.
uh....i used to 90deg ice picks
either kit, marquette or ECS are good choices.
I prefer to patronize marquette myself due to no shipping or sales tax suprises as I am in ohio and marquette is in PA. |
Do it! |
Sorry, forgot it was on Vortex. It's also Vasillalov.
http://forums.vwvortex.com/zerothread?id=2271429 |
| Timing belt change | david_fouts | 1.8 Liter Turbo | 11 | 11-25-2007 08:37 PM |
| Timing Belt Change | Silber Igel | 1.8 Liter Turbo | 6 | 08-27-2006 01:44 PM |
| Problems after Timing Belt change | SLOW98NB | 1.8 Liter Turbo | 11 | 08-20-2006 09:31 PM |
| Time for timing belt change? | Beetlebomb | 2.0 Liter Gas | 3 | 10-23-2005 12:14 PM |
| Timing belt change complete. | jbehm | 2.0 Liter Gas | 12 | 10-22-2005 09:56 PM |
