Hi everyone...I'm new to this forum, I drive a G35 and my girlfriend has a Beetle. Well her Beetle has experienced some cooling issues recently I.E. no heat,red temp warning light.
I pulled her codes and got coolant temp. sensor(but the fans are turning on when needed), I figured maybe the thermostat was no good, Well I replaced that and I'm still getting no heat and the red temp light. I have a Haynes manual it list the following as possible problems water pump(still working) surge tank cap(haven't checked) thermostat(replaced) clogged radiator head gasket(the car runs fine so I really don't think it is a head gasket) Can anyone shed any light on my situation and help me out? Does anyone know if their is a bleeder valve to purge the cooling system? Any help would be greatly appreciated...Thanks G35Ian |
unless you get a metal water pump and it will last forever....even a plastic one ill last over 60k
The only advantage the metal impeller pump has is that the impeller doesn't spin off at random.
How do you "know" the water pump is working? Is coolant circulating back into the tank when the engine is running? Is the coolant level full? Have you tried replacing the coolant level sensor? |
Egotism is the anesthetic that dulls the pain of stupidity -Leahy |
WOW I just read your whole thread that was pretty impressive |
| Air in cooling system | Babycar | 2.0 Liter Gas | 2 | 06-28-2008 05:52 PM |
| Fragile Cooling System | 3lowdown | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 03-25-2008 01:09 PM |
| Air in cooling system? | hillbilly4u | 2.0 Liter Gas | 2 | 12-03-2007 12:24 AM |
| Cooling fan surging issue | e-dad | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 10-01-2007 10:35 PM |
| Anybody know how to bleed the cooling system ? | jlag | 2.0 Liter Gas | 4 | 09-08-2006 03:11 AM |
