changed timing belt , turns over but not firing - NewBeetle.org Forums
Old 03-12-2009, 09:27 AM
Default changed timing belt , turns over but not firing
beetle petrol 1.6l 2001
i have just done major overhaul on beetle and now shes not firing
i have replaced head gasket, oil seals,timing belt and water pump (shot! plastic impellor in pieces)
lined up timing belt
car now turns over but will not fire
i have vag and the error is
16725 camshaft position sensor (g40) implausible signal
what could this be never had no problem with sensor previously so im assuming timing marks are out
any ideas before i strip down again?
thanks
Old 03-12-2009, 01:41 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Just a silly question, did you reconnect the the CAM Sensor wire?
Old 03-12-2009, 08:18 PM
jumped a few teeth was the problem
Old 03-16-2009, 02:00 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
woah, jumping a few teeth is more than a problem, you might have some serious damage if you jumped one tooth.
Old 03-16-2009, 03:54 PM
vdubbugman53's Avatar
Arvada, CO, USA
on a 1.6 i bet she is fine.....not all motors are interference
I did it! I changed the timing belt myself kdurfee 1.8 Liter Turbo 4 09-10-2006 08:07 AM
Timing Belt Changed!!! marvins_dad 1.9 Liter TDI 11 06-09-2006 11:39 AM
Timing belt & Water Pump changed now fatdaddy 2.0 Liter Gas 8 03-19-2006 08:14 AM
I had Timing belt and Water Pump changed now the Check Engine light fatdaddy Questions, Issues, Concerns, or Problems with the New Beetle 15 02-13-2006 02:27 AM
