How long did you run it originally with the engine overheating?
You could have warped the head and cooked the head gasket originally when the water pump went out.
maybe.....i drove 67 miles with that damn red light on and the car beeping at me(i was so pissed of at my car i didnt care if it started on fire))....granted i still had a few fins on my impeller the water was still boiling when i got home...he should be fine
Head needs to be pulled and checked for straightness before installing new gasket. |
i say put a new water pump in it and if you dont lose any coolant through they cylinders then your fine....no need to spend money that may not be necessary. if you burn coolant then replace the head gasket....you will know if you have white smoke coming from the cars exhaust...might even see water from where the head sits on the block
Well I didnt ran that far (less than 3 miles and I just replaced the waterpump,and all that I mention. Then my coolant looks like its gets empty so fast ,. is that means Im burning the coolant ,there is no leaks anywhere that I can see..So I think the HEAD GASKET THEN.
is the car smoking? if the car isnt smoking then you probably are not burning coolant. with the car off fill the tank and then let it warm up with the heater on. if you ad more then 2 gallons then your losing it somewhere and yes it could be the head gasket.
i just dont think your gasket is bad |
Check your coolant flange, its on the driver side of the engine under the airbox, they are notorious for leaking, mine was leaking horribly till I fixed that. As for the heater Ide say you have alot of air in the lines and not enough coolant, turn the car on, jack heat up and keep filling it till it wont take anymore.
| Temp red light blinking | Paradoxx | 2.0 Liter Gas | 15 | 04-27-2009 07:59 PM |
| Temp & oil light blinking like crazy | lawlesseyes | Questions, Issues, Concerns, or Problems with the New Beetle | 27 | 01-14-2007 03:48 AM |
| ABS and Brake light blinking/beeping | Javaholic | 2.0 Liter Gas | 13 | 04-18-2006 02:22 PM |
| Blinking Red Temp Light | BBBEAR | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 10-26-2005 04:18 AM |
| Blinking Temp Light | SCbuggin | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 10-23-2005 12:54 PM |
