Help - many warning lights! - NewBeetle.org Forums
Old 03-14-2009, 10:28 PM
Default Help - many warning lights!
Was driving today and suddenly many warning lights came on, one right after another.
Battery, Brake, ABS, oil, warning bells. All gauges (speedometer, gas, tachometer) went to zero.
WTF!? Checked oil it is fine.
A few yrs ago, when the battery went bad, first that happened was gauges went to zero. But, not all the others.
What could be happening?
Old 03-14-2009, 10:55 PM
hestersu's Avatar
Canyon, TX, USA
Please provide year, transmission (auto, manual), engine, miles on car, any modifications done to your car - especially something involving the electrical such as aftermarket radio or other audio and where you are located.
It will help those that can help you better.
Also list any maintenance done to your car, especially recently.
Susan Hester
Former owner of:
Old 03-14-2009, 11:02 PM
Its a 2.0 liter 1999, automatic, no modifications,about 30K miles.
Few mths ago had timing belt, water pump changed. Oil change. New battery in 11/07.
Old 03-14-2009, 11:13 PM
vdubbugman53's Avatar
Arvada, CO, USA
your gauge cluster might have $hit the bed. where are you located....a vag com could tell you if the cluster is bad
Old 03-14-2009, 11:18 PM
I'm in Maryland. If this is the problem, is it ok to keep driving the car for a while?
Is autozone still in business?
Old 03-14-2009, 11:20 PM
Arvada, CO, USA
well they could tell you if there is any check engine lights and what it was for....if it is just the cluster then yes you can drive it like that.
get on the vortex regional forums and find somebody with a vag com near you
Old 03-14-2009, 11:23 PM
what is the vortex regional forums?
Old 03-14-2009, 11:28 PM
Arvada, CO, USA
http://www.vwvortex.com/index.html <--vortex
http://forums.vwvortex.com/zeroforum?id=351 <<------YOUR Vortex Regional forum
Old 04-06-2009, 05:12 PM
This same symptom happened to me and it turned out to be a bad cell in the battery and leading to a bad alternator. The first light that lit was the red battery light and shortly all the lights, tach and speedometer would go berserk. Changed out the battery and alternator and all is well now.
Electrical problems/warning lights/radio Dr. Greg Questions, Issues, Concerns, or Problems with the New Beetle 3 03-07-2009 08:57 PM
Warning Lights Tower of Babel mayagrafix 1.8 Liter Turbo 3 01-06-2009 07:08 PM
warning lights on new bug B's Bug New Beetle Convertible 2 05-17-2007 04:07 PM
CEL and other warning lights geezerb 1.9 Liter TDI 3 12-15-2006 02:57 AM
Missing warning tones & cluster lights? nroakley Questions, Issues, Concerns, or Problems with the New Beetle 7 07-25-2006 03:43 PM
