I've got 2001 GL that has sat for a week and the battery is Dead. I put in a new Battery 2 months ago and have had it and the alternator check 2 weeks ago and they checked fine. Is there any way to check and see what is draining the battery.
I have turn off every thing I can. |
Off the top of my head... check the ignition switch.
When you pull out the ignition key, to you hear a "clack" sound? The ignition is a switch, and by just inserting the key, the switch is turned on, pull the key out it is turned off. |
couldn't be if i pull keys out too fast, the switch stuck on "on"? |
Grab yourself a test light (bulb type). Turn off the interior lights so they don't give you false readings. Disconnect the battery and put the test light between the cable and the battery. Any current draw will go through the light and illuminate it. If it was killing the battery in a couple hours, this would be too much current to run through the test light, but it sounds like yours is pretty small.
Pull fuses and keep an eye on the light. When the light dims, you found your draw. A normal draw (memory backups, etc.) will very dimly light the bulb. Once you find the fuse causing you problems, you'll need to trace down the individual item it feeds, but it will be a lot easier at that point.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW 04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust. 57 Beetle Oval Window Sunroof 2 powerstrokes, Thing, Fox, Dune Buggy...... |
| Key battery dead | Turboboy | Questions, Issues, Concerns, or Problems with the New Beetle | 16 | 01-24-2009 11:53 PM |
| 99 gls dead battery or alt. or what?? | Midwest_beetlebug | 2.0 Liter Gas | 16 | 06-09-2007 03:16 AM |
| NBC Battery Dead | bagman | New Beetle Convertible | 3 | 12-13-2006 05:25 AM |
| 99 Battery going dead Please Help! | C.Hotchkiss | 2.0 Liter Gas | 1 | 10-29-2006 05:17 PM |
| Dead battery or..? | quiong | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-11-2005 04:15 AM |
