2003 vw knocking / gas problem - NewBeetle.org Forums
Old 03-19-2009, 12:42 AM
Question 2003 vw knocking / gas problem
when my car sits idle you hear a knocking/ticking type of sound its not the fans on the radiator, its coming from the belt on the alternator kinda sounds like a compressor not sure, usually when you start the car no matter how warm it is if you let ti sit you hear it very well inside the cab
Old 03-19-2009, 02:03 AM
mernst's Avatar
Which way did he go!!!!!
Gulfport, MS, USA
Car: 2000 Turbo GLS
sounds like the water pump...
Mine does that too, it runs for 5 mins sometimes...
Old 03-19-2009, 02:55 PM
anyone else got any answears for me please?
Old 03-19-2009, 06:42 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
What exactly do you want to hear...? Off the top of my head the parts noted below could, possibly make ticking sounds in addition to the water pump suggested earlier...
1) A/C Compressor clutch
2) Alternator Pulley
3) Timing Belt Tensioner
4) Serpentine Tensioner
5) Cylinder Head Valves
6) Cam Bearing
7) Crank Bearing
2003 window problem (won't go down) Batguano New Beetle Convertible 9 04-12-2009 10:57 PM
knocking/clicking when A/C is on....... zyonasan Questions, Issues, Concerns, or Problems with the New Beetle 5 07-05-2008 03:57 AM
Knocking Noise iamregin Questions, Issues, Concerns, or Problems with the New Beetle 6 07-02-2008 04:27 AM
Knocking Sound? 1.8TurboChick 1.8 Liter Turbo 11 09-03-2007 05:47 PM
Knocking and smoking. geo2slow4u 2.5 Liter Gas 4 08-02-2007 10:11 PM
