Cruse Works Part Time - NewBeetle.org Forums
Old 03-19-2009, 06:45 PM
Default Cruse Works Part Time
I bought a 2000 beetle for my 16 year old daughter, and the cruse control will work for awhile and then just quite's until you stop and turn the car off, when you restart the car it works fine for awhile again. Also noticed that the cruse light on the instrament panel never lights up. If anyone has any suggestions please help.
GCK
Old 03-19-2009, 08:43 PM
gforce1108's Avatar
Port Jervis, NY, USA
Car: 98 Beetle TDI
There probably isn't a light for your cruise. Seems to vary between years and models, but here's a thread on the same subject:
http://forums.tdiclub.com/showthread.php?t=227511
Someone mentioned it was added in '02
If you have access to someone with VCDS (Vag-Com) there's some quick tests that can't be run that show the status of all of the switched associated with the cruise control. There's the actual switch to turn it on, the set switch, brake switch and clutch switch (manual). I think some even have 2 switches to tell both up and down position of the pedal. In VCDS they are all grouped together in one line so it's easy to test.
Without it, you'd need to ohm out each one.
98 Beetle TDI sprint 520s, KP39 turbo, fully straight piped My 29th VW
04 Jetta TDI RC3, vnt17/22, FMIC, side exit exhaust.
57 Beetle Oval Window Sunroof
2 powerstrokes, Thing, Fox, Dune Buggy......
Old 03-19-2009, 09:46 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
My '98 use to to do that and then after the brake switch recall it has not done it.
There is no "Cruise" dash light on my '98, '99 or '00T.
Old 03-21-2009, 05:48 PM
Thanks for the help, hope to get to return the help one day
Old 03-28-2009, 05:37 PM
Benny Beetle's Avatar
Are Friends Electric?
gurnee, IL, USA
Car: manual y2k gls 2.0
In case you may still have issues, I thought I'd offer my experience with that issue...... I had a burned out brake light. When the bulb was replaced cruise worked just like it should.
Old 03-28-2009, 08:40 PM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
Daisy has had occassional cruise issues. I set the cruise and the car accelerates until I brake or is limited by the gear it's in. A couple weeks ago it didn't want to set the cruise so I pulled over, turned it off and then it worked. Crazy car! Brake light switch has been replaced.
No cruse control.. Help! jasonwinters3 1.8 Liter Turbo 5 11-23-2008 12:39 AM
First Time New Beetle Owner, VDubbin for a long time...Meet Mojo Jojo icyustare Photos: New Beetles 30 05-29-2007 02:28 AM
Long time lurker, 1st time poster and 1st time owner hmmdonuts Photos: New Beetles 30 03-21-2007 05:39 AM
Vibrating sound on acceleration part of the time Beetlebomb Questions, Issues, Concerns, or Problems with the New Beetle 0 10-03-2006 03:52 AM
Got another part time job! jdesigns Miscellaneous Hoo-Ha Archive 20 11-10-2005 04:52 PM
