2000 beetle auto with 145k miles.
New parts as listed-- Battery -3 months Alternator -2 weeks Ignition Coil -1 day Spark plugs -1 day Spark plug wires -1 day Air filter2 weeks -2 weeks Oil/ Oil Filter -1 week Cataytic converter -1 day Code p0301 p0303 Missfire cylinder 1 and 3. Checked all the fuses and they're fine. I'm not sure as where to go next. The cataytic converter was bad i could tell, i really thought it was that. The inside was moving around when i took it off and would rattle in low rpms. Replaced and not the problem. So any input of this would be really appriciated. Thanks! |
Found a few internet entries for P301, P302 etc etc which were difficult to cure. I didn't find a resolution while browsing!
I did come across this though : 01 02-07 10/25/02 Golf, Jetta, Jetta Wagon, New Beetle w/ 2.0L (AZG adn AVH), 2002 Misfire, Incorrect Cylinder Identified by ECM Software Fault codes P0300 along with P0301, P0302, P0303, or P0304 stored in DTC memory. (ECM reports incorrect cylinder that misfires.) I would have your plugs out one at a time and review their condition. This may indicate which cylinders do have problems if the above applies to your car. If certain cylinders aren't firing properly then it's probably a coil pack change. With these error codes not the AMM, or catalytic convertor or lambda sensors or an intake leak although there is no harm in checking all pipework. good luck, Ian
Ian Royal Air Force Aeromechanical Engineer 2001 2.0 New Beetle 72k miles ... engine light on already ! |
Are you sure you have your coils connected correctly?
Try disconnection your 1 and 3 lines from the coil to see if it still misfires When you say your ignition coil is new is your distributor new also? If all else fails you might have a real bad pressure leak and might need to do a pressure test. |
| Tags |
| 2000 , beetle , misfire , missfire |
| 2000 VW Beetle 2.0 | lilloui05 | Engine Swaps | 5 | 04-18-2012 05:30 PM |
| newer front bumper on older beetle 05-08 on a 2000 beetle | turbobugger | Paint and Body | 4 | 01-27-2009 09:03 PM |
| Road trip tomorrow and now have a missfire | blackbeetle99 | 2.0 Liter Gas | 5 | 10-06-2008 02:35 PM |
| 2000 New Beetle 2.0 | BASIK203 | Photos: New Beetles | 3 | 07-29-2008 04:05 PM |
| Cylinder 1&2 missfire. | 25PSi | 1.8 Liter Turbo | 6 | 04-14-2008 10:52 PM |
