brake light flashing/abs light on - NewBeetle.org Forums
Old 03-24-2009, 11:28 AM
Default brake light flashing/abs light on
2000 beetle, auto, loaded, 191k
I pulled the battery to clean the ground point that is under the tray. Now, the ABS light is on and the brake light blinks.
Also, the cruise control no longer works and i can't get the AC compressor to kick in.
what gives? gremlins?
thanks for any help,
74transporter
Old 03-24-2009, 12:09 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
So what prompted you to clean the grounding point in the first place?
Old 03-24-2009, 12:22 PM
Crazy_MoFo's Avatar
It's a shot glass!
Back Home Again( O.C. SoCal), USA
Car: '98 Cool White 5 Speed 2.0L GL
my NB has the ABS/Brake light flash and ding ding ding gremlin. Does it once in a while. Dunno what it is.
"It's not a bud vase. It's a shot glass"
Old 03-24-2009, 03:20 PM
D2Beetle's Avatar
NB Yellow Trifecta
Off the top of my head...
1) Ignition Switch
2) Convenience/Comfort Control Module
3) ABS Module
4) Brake Sensor
5) Battery Top Casing/Fuses
Old 03-24-2009, 06:28 PM
Genesis's Avatar
Virginia Beach, VA, USA
Car: 2000 GLS
1) Ignition Switch
3) ABS Module
4) Brake Sensor
My guess would bue 5) Battery Top Casing/Fuses. What and how did you clean the battery post terminal. If you used the a liquid, then they it's probably still wet and not getting good contact points. Worse case, you have blown some fuses.
Old 04-05-2009, 10:03 PM
i had popped a couple fuses trying to jumper a sensor to cause the compressor to kick on.. everything works except AC now, which is why i pulled the battery to clean that ground point. read that somewhere online..."clean this ground point...its a source of many gremlins..."
anyway, no AC. no power to the compressor. the haynes advises to short a sensor to kick the compressor in. my sensor (in the alum AC line on the top, on the left in the back) is three prong.
any advice towards trblshooting this ac appreciated.
Brake Warning light flashing. wabanaki Questions, Issues, Concerns, or Problems with the New Beetle 5 02-29-2012 01:21 PM
Flashing brake warning light AND ABS stays on? Flopka2 Questions, Issues, Concerns, or Problems with the New Beetle 10 07-09-2010 04:38 AM
ABS light on + brake light flashing Nounours Questions, Issues, Concerns, or Problems with the New Beetle 2 04-01-2008 10:45 PM
Flashing brake light, beeping. Lmhansen Questions, Issues, Concerns, or Problems with the New Beetle 6 02-13-2007 11:22 PM
