where are vacuum hoses - NewBeetle.org Forums
Old 03-24-2009, 07:37 PM
bertybug's Avatar
leicester uk, leicestershire, United Kingdom
Car: 2001 2.0ltr Black 5 speed
Default where are vacuum hoses
please can anyone help me i need to change vacuum hoses and i dont know where they are............. also if anyone has a link with pictures that would be great?? i just do not wanna pay some garage to do it!! please help
To loving Bugs!!
Old 03-24-2009, 10:04 PM
bertybug's Avatar
please help me
Old 03-24-2009, 11:04 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Vacuum lines are usually small diameter, flexible hoses that run to and from various components. I'm not sure about a 2.0, but in the case of TDI engines, the vacuum lines are covered in braided black cloth with white stripes. They often come in different sizes, and you should be able to pick up some replacement line in bulk from the dealer or another auto parts store. There may be some specialty vacuum hoses that would be a VW part, the line going to the brake booster for example would be a specialty part rather than just a piece of hose cut-to-fit.
If you want to go through and replace all of your vacuum lines, you can do so. Do it one at a time and cut each new one carefully to length. Be careful when removing the old line. If you are pulling them off a plastic nipple they will often stick and you can break the nipple if you're not careful. Slitting them with a sharp utility knife is helpful, just don't cut too deep or you will slice through the plastic nipple as well.
2000 New Beetle GLS TDI
Old 03-24-2009, 11:05 PM
DZLBUG's Avatar
I Am Breitbart
By the way...what problem are you experiencing that you feel the need to replace them?
Old 03-25-2009, 09:37 AM
bertybug's Avatar
engine check light code p0411 secondary air injection system faulty air flow......... im just hoping it is just a cracked hose as now my bug has started to sound like a hoover when i start the engine it only last for a couple of minutes then goes of so i suspect it could well need a new secondary air pump !! i just hope thats a do it your self job too has the credit crunch is hittin rather bad here in uk and people just simply cannot afford to take there cars to mechanics!! thanks so much for your help
Old 03-25-2009, 08:29 PM
bertybug's Avatar
I checked the vacuum hose to the back of the combi valve and it appeared to be cracked right where in joins. I assume that, that is the combi valve lol its the round brass colored valve about 2 inched in diameter that sets on top of the exhaust manifold just to the rear of the MAS coupler? Kinda of hard to get to, or should i say very hard to get to!! today i got 4mm silicon hose will this be ok to use???
Old 03-25-2009, 09:35 PM
DZLBUG's Avatar
I Am Breitbart
Is the silicon hose you got meant to be used as vacuum line? It just needs to be firm enough to not collapse and needs to be proper size. If it looks/feels the same as what is on there you will be fine. Give it a whirl.
Can't answer your other question as I'm not familiar enough with the 2.slo engines...sorry mate.
Old 03-25-2009, 09:57 PM
bertybug's Avatar
its ok u have been a great help.........yeah the silicon hose i have is vacuum hose and its very firm......... cheers mate
Old 03-26-2009, 06:11 PM
bertybug's Avatar
job done........ was quicker doing it than i expected thanks for your help
samco hoses FallinApartBoy 1.8 Liter Turbo 21 09-02-2011 06:16 PM
Vacuum hoses Mr_Eddy Technical Modifications 5 03-04-2008 06:01 PM
Vacuum Hoses vibelife 1.8 Liter Turbo 17 12-31-2007 10:43 AM
Vacuum Hoses from H--- ben73058 1.8 Liter Turbo 14 12-21-2006 10:52 PM
Vacuum Hoses . . . . EvilinaDM101 2.0 Liter Gas 1 04-01-2006 05:45 PM
