Sunroof sunshade help - NewBeetle.org Forums
Old 03-29-2009, 09:39 PM
jimsvw's Avatar
Default Sunroof sunshade help
I got a 01 NB GLS in Decemeber. Now that the weather is warmer here in NE Ohio I am trying to get the sunroof to go all the way back, but it stops about 1/2 of the way in the open/ slide back position. It WILL go all the way up in the tilt open position. The previous owner had the motor for the sunroof replaced in the fall. He gave me three (3) black plastic pieces, triangular shaped, that he said came out of the space above the sunshade in the roof when they were working on the sunroof.
The sunshade will only go about 1/2 to the closed position. It will go most of the way back, but I have to struggle with it. It looks like on the drivers side, the sunshade may be missing a slide? Does anyone know what these 3 black pieces may be, and how I can put them back in or have to replace them?
Will I have to take the glass off and then remove the sunshade?
Bentley manual is on the way.
Thanks Jim in NE Ohio
Old 03-29-2009, 10:21 PM
Sharonville, OH,
Car: 1999 GLS 2.0L 5-spd Silver Arrow
Hi Jim,
Below is a DIY for replacing broken sunshade glides:
VWvortex Forums: DIY: Removing sunroof, fixing shade guides
You can buy the glides here:
Volkswagen Jetta IV 2.0
If you only need one or two replacement glides, you can probably sell the leftover glides from the kit here in the classified section.
Good luck!
Becky
rear window sun blind / sunshade curly Styling Modifications 10 06-10-2011 05:39 PM
sunroof? robpad Questions, Issues, Concerns, or Problems with the New Beetle 1 01-14-2008 11:35 PM
sunroof off track angelusnhc 2.0 Liter Gas 1 07-28-2006 03:22 AM
Sunroof CUL8R Styling Modifications 2 04-07-2006 04:05 PM
SunShade Glide Replacement - How-To marvins_dad Technical How-To 0 09-19-2005 10:47 PM
