No no no NO! Power steering fluid IS NOT brake fluid!
You need this...regular power steering fluid that you buy at an auto parts store will not work: PENTOSIN Power Steering Fluid CHF 11S (Compatible w/ VW ® / Audi ® G00-400-0M2 / G004000M2)
I didn't find anything in the owner's manual and my Haynes book just says "VW hydraulic fluid". Thanks for the recommendation. I'll be picking up a can and replacing the fluid (likely 10 year old sludge).
Between the g-forces and the fumes, I get a good buzz. |
And just so we are clear...you are checking the power steering reservoir with the green cap that is attached to the battery box correct? |
Yes green cap resevoir next to the battery box. Someone else that owned the car before me must have put brake fluid in the power steering resevoir. I swear it smells and looks just like brake fluid. I have the correct power steering fluid on order and will suck out all the old stuff and use the correct fluid. No problems as of yet. The power steering still works great. |
Thanks, I am aware of VW/Audi fluid, that is what was used, but I was hoping someone might know what the repercussion might be as I know that it did get mixed by someone with good intentions.
Well, that ounce or two of brake fluid will have to stay in my power steering for another couple weeks until I have more money to have that taken care of, hope there won't be more serious problems. I just spent $300 on the cv boot a couple days ago (and a couple weeks before that the brakes, that's when the fluid was added). My 27 point inspection mentioned needing to do $200 worth of something else with a gasket and something with fluids for trans/power steering (don't recall the exact wording on that pre-printed form). Need the 75k oil done too, NOW, but that will be done then, I'll just drive with a heavier foot since I know I'll "use" oil and then add more fresh until then. Last edited by Benny Beetle; 09-18-2009 at 01:28 PM.. |
| Power steering fluid leak | Sukhoidave | 1.8 Liter Turbo | 5 | 12-29-2009 04:38 PM |
| I have a power steering fluid leak | Sukhoidave | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 11-23-2008 01:51 AM |
| What power steering fluid should I use? | doublebarrel | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 08-06-2007 04:13 AM |
| Power Steering Fluid | NCtim | 2.0 Liter Gas | 2 | 03-30-2006 02:20 AM |
| Power Steering Fluid | kiltedbeetle | 1.8 Liter Turbo | 8 | 01-04-2006 04:23 PM |
