where is my coolant leaking from? - NewBeetle.org Forums
Old 05-12-2009, 08:56 PM
Default where is my coolant leaking from?
Hi, I observed that my coolant leaks from what it appears the area of front crankshaft oil seal. There is no oil leakage whatsoever and the fluid that is dripping does not indicate suggest there is oil in it.
I thought maybe the crankshaft front seal is bad, but then I asked myself: what would a coolant do in a crankshaft area since I believe there is only oil there.
I talked to a mechanic very casually and over the phone and he said that it is the water pump that is likely to be bad.
I would believe that, BUT
...the thing is that there is NO coolant leak paths that run from the waterpump down to crankshaft front seal.
Has ANYONE had similar situation and if so, then what was the solution?
Thanks,
Old 05-12-2009, 09:41 PM
Tesla's Avatar
Y2K Speedle
Car: 2000 Beetle 2.0 Manual
Hm... first place to see the coolant leaking on my 2.0 2000 175K bug was on the coolant flange seal. To be more precise, I could smell the coolant when I turn the heating fans on so I pop the hood and found the white dry stuff around the coolant flange seal area. Got the new one from the local part store ( $13.85 CAD ) and replaced it my self. Took me 1 hour
Good luck
Go out and ride
SPEEDLE
Old 05-14-2009, 04:08 PM
Atlanta, GA, USA
Car: '99 GLS
newbie, I've got the same affliction. my guess is the waterpump too but it was supposed to have been replaced just recently by the prev owner.
any other suggestions from the forum?
Tags
coolant
Coolant pipe leaking near intercooler bman 1.8 Liter Turbo 3 10-30-2008 07:21 PM
Leaking coolant - drive it? Audiophil 1.8 Liter Turbo 7 10-26-2006 12:00 AM
Leaking Coolant, Help!!! GraceIsotope 1.8 Liter Turbo 3 07-28-2006 12:22 AM
Leaking Coolant, Help!!! GraceIsotope New Member Forum 5 07-28-2006 12:18 AM
Coolant leaking bdlbug 2.0 Liter Gas 4 10-26-2005 12:25 AM
