I have a 2003, 2.0L that gets engine oil in the cooling system. I drained the cooling system and flushed it as clean as possible. I added 2 quarts of oil, back to the full level on the dip stick. I can find what looks like new oil in the cooling resevor in a very short time of driving, 20 miles or so. The car runs great and seems to have no other problem other than pumping the engine oil into the water resevor. Got any ideas??, |
The oil cooler is cheaper and easier to replace. As a test, you could probably remove the coolant lines (connect them together) and run it that way for a little while. If it's leaking, you should see oil dripping out of the cooler.
No .... I didn't find the problem, it seems that as soon as one problem is solved another one comes up. I've never had a car with so many issues that need something special from VW.
Example: Coolant, P/S fluid, Trans fluid/levels and that's the short list of common things that should not be a big deal. |
| Water in my bug | senna | New Member Forum | 5 | 05-09-2008 05:52 PM |
| Water Spots Water Spots... *drip* | kate_the_valkyrie | New Beetle Detailing/Cleaning | 7 | 04-30-2008 02:28 PM |
| 2.0 playing in the water water VID!!! | vdubbugman53 | 2.0 Liter Gas | 8 | 11-18-2007 12:41 AM |
| Where did this water come from? | BeetleRobb | Questions, Issues, Concerns, or Problems with the New Beetle | 8 | 12-30-2006 03:56 AM |
| Looking for Water | PhoenixRising | Jokes | 0 | 05-26-2006 01:58 AM |
