How aweful!! I sure hope it's not the TB!!! That could mean some serious issues and possible engine damage. Poor Bailey! I know what's it's like to have your kid at the shop and be borrowing something else. It sure does give some massive withdrawls. Hope Bailey gets better soon!!!
Just because it's done at a Dealer, doesn't mean it's done Right!!! "Probie" 2k12 ToD Checklist Dub Gestapo |
Oh, I am so sorry.
I hope your baby gets better soon. Keep your chin up, it will be okay. I had the Turbo go out on my NB last year. Lucky for me it was under warranty. I don't know if that my be what is your NBs issue, but it kinda sounds like it. I hope not. Good Luck to you. ![]() Edit: Does the 2.0 have a Turbo? |
Update:
Bailey is still in the hospital ![]() ![]() So far, the mechanic has tested: The fuel pump, it's ok. The MAF sensor, it's ok. Exhaust is fine, so it's not the catalytic converter. still has no acceleration.Next to test, I believe is the timing belt. ![]() |
I wish you luck on Bailey. Somebody correct me if I'm wrong, but if it happens to be the timing belt, it is better to catch it now rather than if it broke. Anyway, good thoughts and plenty of prayers your way that it won't be as bad as you fear. HUGS
LET'S MAKE SURE HISTORY NEVER FORGETS THE NAME "NEW BEETLE" |
gosh I hope it's not the TB! Though I don't know if a broken TB would cause no acceleration. I think the engine would make a really awful noise then over heat and die. But I'm not 100% sure on that either. Keep us posted! |
A broken timing belt would absolutely cause no acceleration--no running at all in fact.
But she runs, so thankfully it may not be the TB. Very weird. Was she overheating? Hows your thermostat?
The 2.0 is not a turbo engine.
I hope your NB is fixed up soon! ![]()
Former VWs: 2002 NB Turbo S - Platinum Gray 2003 NB TDI - Galactic Blue 2005 NBC 1.8T- Tornado Red 2006 Passat 2.0T- Blue Graphite 2003 NB Turbo S - UniRed 2005 V6 Touareg V6 - Campanella White Currently: 2002 NB GLX 1.8T - White Paint |
As others have said, it's not the timing belt.
There's NO WAY the engine would still be running if it was the TB, and as far as I know, they fail catastrophically, not incrementally. Have you checked the compression or to see if there is oil in water/water in oil? My guess is that it's the head gasket. |
Update:
The good news: It's NOT the compression/head gasket. NOT the TB. NOT the injectors. NOT coil pack, leads or plugs. NOT the fuel pump/filter. NOT the MAF/oil/temp/o2 sensors. The bad news: She starts and idles. Put your foot to the accelerator...she coughs, sputters and pukes. Conclusion: The ECU is in some way corrupted. Now the search is on for an ECU for her. Need to have the dealership code it...etc.... ![]() |
After what seemed like 3 very longs weeks...Bailey is out of the garage.
![]() Bailey actually had more than one thing wrong with her.. She was misfiring, and only running on 2 cylinders. To fix this we replaced the coil pack (known to go faulty in beetles). At the same time, the plugs and wires were changed. We figured that while he was changing the coil pack, we'd just have him do it all (prevention rather than necessity). She then, wasn't starting. She would start as long as the key was in the crank position, as soon as you let it go to return to the run position, she would die. We bought a reconditioned ECU, which helped, but did not cure the situation. On further examination, it was evident that the ECU wasn't getting live data (which means that something was preventing the ECU from powering up and distributing the correct information to the rest of the car, causing the car to cut out). Relay by relay, our mechanic pulled and tested relays. End result: Relay 100 (located under the air filter box) was faulty. After replacing that, she started right up, and ran like a dream!! Not that money grows on trees or anything, but while the mechanic had Bailey so far apart, we had him change the known problem issues that beetles are notorious for (fuel filter, pollen filter, MAF sensor, timing belt/water pump kit). Again, prevention rather than necessity. Happy days!!We still have one more issue tho, and she just started doing it today... As soon as you start the car, the coolant fans (both of them) come on, and go straight back off, within a few seconds they come back on, then off again, continuously. Any thoughts?? |
