Oil change with extractor - what to do about filter? - NewBeetle.org Forums
Old 06-22-2009, 04:15 AM
Default Oil change with extractor - what to do about filter?
For all those extractor oil change fans, how do you go about changing the filter? Is it possible to change the oil filter without using ramps, by simply crawling underneath the car?
Or, do I absolutely need ramps to do it right?
2004 New Beetle
Old 06-22-2009, 04:20 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
What kind of car you have? A coupe? A convertible? 2.0L engine? 1.8T engine? Turbodiesel engine?
Old 06-22-2009, 04:30 AM
2.0L coupe, thanks.
Old 06-22-2009, 04:32 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
I used to change it by shimmying under the passenger side and just loosening the oil plug with no rams. As for the oil filter, it isnt terribly concealed but its going to be a bitch to get off and you might just have a few oil slicks on your driveway for a while
Other than that just go to wally world and get some jack stands for like 10 dollars and jack it up.
Old 06-22-2009, 07:49 PM
Tay272's Avatar
Zionsville, PA, USA
Car: 98 2.0 Silver Arrow
What I do when I change mine is get 2 pieces of inch thick plywood and just drive the front wheels up on them. Gives you enough clearance to get under the car easily and still work on it. Cheaper then buyin ramps or jackstands if your not tryin to spend money on anything.
98 2.0 Beetle: UR Lightweight Underdrive Pulley set, Custom Intake, Remus Sport Muffler, VF-Engineering Dogbone mount, Eurosport Upper Strut bar, Autotech 28mm Hollow rear swaybar/poly bushings, CF Hood, Kerscher CF rear spoiler, Xenon roof spoiler, Smoked turns, Black tails. (Coming soon: Fully rebuilt head with TT HD valvetrain, TT 260/256 cam, Neuspeed Supercharger, Chipped ECU.)
air filter change shellbug 2.5 Liter Gas 20 04-26-2009 10:39 AM
Update on PELA extractor and oil change Danbike 2.5 Liter Gas 3 04-09-2008 09:53 PM
How often should I change my filter pack? Bug-Tamer Questions, Issues, Concerns, or Problems with the New Beetle 4 01-06-2007 12:17 AM
DIY Oil & Filter change a snap mel72349 1.9 Liter TDI 7 11-14-2006 04:50 PM
K & N Filter change Silver04 Technical Modifications 8 09-28-2006 05:07 PM
