Squeaking Front Wheels - NewBeetle.org Forums
Old 06-25-2009, 12:54 PM
02newmag's Avatar
Reading, Reading, United Kingdom
Car: 2.0L 2002
Default Squeaking Front Wheels
what can cause the new beetle to squeak in the front of the car when going over bumps. Ive had the bushes replaced quite recently so i dont think its them. anyone have any ideas. do the suspension things need greasing?
Old 06-25-2009, 01:39 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
What bushings were replaced? Lower control arm? Front control arm? Swaybar?
Failing ball joints could also make squeaking noises.
2000 New Beetle GLS TDI
Old 06-25-2009, 01:58 PM
noR's Avatar
Administrator
Jackson, MS, USA
Probably the sway bar bushings need to be greased.
Occasionally; all your bushings need to be greased. There's no fittings for them, you just have to get to them and apply a lil' lube. After 7 years, it's probably just worked itself out.
noR | me | Phrog
PHROG
Old 08-01-2009, 07:19 PM
02newmag's Avatar
Car: 2.0L 2002
cheers for the ideas guys. the sounds stopped for a while so i stopped caring,but now they are back. it seems like in the warm dry weather this is when they are worst. what do you all think it could be then. if it is that they just need greasing i will book the car in for a lube service.
Old 07-08-2010, 02:14 PM
02newmag's Avatar
Car: 2.0L 2002
can i reopen this thread. I had all of the bushes on the front end of the car replaced last week because its hot here and the squeaking has got out of hand. Now however it has returned after being gone for a week. Does anybody have any idea on what else the problem could be... it must be something to do with the suspension because it disappeared after everything was replaced, but have no idea on what else it could be.
any ideas...
thank you
Old 07-08-2010, 03:18 PM
noR's Avatar
Administrator
Jackson, MS, USA
dry bushings make noise. apply grease to the parts that rub/move. if it only happens when you go over bumps, try just doing this to your sway bar bushings and endlinks first. That may be enough.
Old 07-09-2010, 01:58 PM
Pierce County, WA, USA
Car: 2000 GL
Could be dry bushings. Could be decaying strut mounts.
WTB: 04 NB front VW badge, and maybe wheels mostasz Parts and Accessories 5 03-15-2009 08:30 PM
Stock Wheels and Front Bumper for sale in Nor Cal Darkstar Parts and Accessories 2 02-03-2008 02:21 AM
Squeaking brake johan_soeriohadi 2.0 Liter Gas 6 12-05-2007 09:57 PM
19x8.5 wheels up front?? DarkAngel1.8t Styling Modifications 4 08-07-2006 03:25 PM
Whistling Front Wheels NBman 2.0 Liter Gas 4 06-03-2006 03:43 PM
