new a/c problem... - NewBeetle.org Forums
Old 06-29-2009, 02:46 PM
_goREDgo_'s Avatar
San Antonio, TX, USA
Car: '01 GLS "Red"
Default new a/c problem...
well we're on a roll here so let's just keep the a/c questions coming. i thought my a/c problems were fixed but...now my a/c comes in and out of service. it seemed pretty random but now i've got it pegged. when i gun the engine my a/c will decrease significantly in coldness and a moldy smell will emit. the compressor fan is still spinning but the temp gradually changes to a higher temp (pretty warm). then as suddenly as the a/c coldness leaves it comes back gradually (the same process but in reverse).
any thoughts on this would be great!
'01. gls. 2.0. uni-red.
"picture me rollin'..."
Old 06-29-2009, 04:34 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Why did you start a new thread? I gave you links in your other thread that should help you if you are mechanically inclined. If you aren't, take it to a competent shop and print that information out for them.
Other thread:
A/C Blowing Cold Then Warm, Humid Air...
Link 1:
Check your radiator/condenser fan operation NOW - TDIClub Forums
Link 2:
http://pics.tdiclub.com/data/517/A4_...ting_Rev_7.pdf
If you read the first link, it will explain how people don't usually notice a problem until the A/C cuts out (which yours is doing). Your fans probably aren't working correctly.
If they are working correctly, the problem may be somewhere else. Read those links. There are a multitude of failure points and I can't just give you a magical answer based on the info you have provided.
2000 New Beetle GLS TDI
Old 06-30-2009, 02:03 AM
_goREDgo_'s Avatar
Car: '01 GLS "Red"
sorry. geez. ::tosses DZLBUG a bottle of Midol::
Old 06-30-2009, 04:33 AM
DZLBUG's Avatar
I Am Breitbart
Dunno what that is going to do since I'm a guy.
I wasn't trying to be harsh or anything, I just didn't figure we needed yet ANOTHER A/C thread when you were already directed to all the info you need.
That is all. Good day.
Old 07-02-2009, 05:11 PM
Default a/c problem
Had a poorly cooling a/c recently. There are 2 fans in front of the engine. One is for the radiator and the other is for the a/c condenser. The one for the a/c was not working. The fix is that you have to replace both fans as they come as a combined unit. Be sure both fans are turning when the a/c is turned on.
oil problem johan_soeriohadi 2.0 Liter Gas 10 10-31-2007 11:58 PM
odd problem deadgirl Questions, Issues, Concerns, or Problems with the New Beetle 2 01-07-2007 05:22 PM
Does anyone else have this problem? shady_lane New Beetle Detailing/Cleaning 2 09-30-2006 07:22 AM
New Beetle - possible the worst car ever made - problem after problem - PLEASE READ John Pemberton The New Beetle Experience 48 06-21-2006 04:41 PM
Another problem.. osprey Questions, Issues, Concerns, or Problems with the New Beetle 1 04-14-2006 02:24 PM
