Retrofit The Aircon VW forgot to install in 2.0l - NewBeetle.org Forums
Old 07-02-2009, 01:42 PM
02newmag's Avatar
Reading, Reading, United Kingdom
Car: 2.0L 2002
Default Retrofit The Aircon VW forgot to install in 2.0l
In the uk some years ago, a load of beetles were shipped over with the aircon missing because vw forgot to put them in. So what i want to know, is it possible to retrofit one in just by buying the various parts that it would have had. i could probably find the parts from a scrapyard quite cheaply from a similar beetle. the thing is what else needs to be changed. would it need a whole new ecu and wiring loom? and would the engine be the right one. Im guessing all of the mounting brackets would be in there for all of the stuff. And havent got a clue on how much work it would be.
Any help would be much appreciated.
Also.If there is somebody on here who has done this i would love to ask you a few questions. Thanks
Old 07-02-2009, 01:45 PM
noR's Avatar
Administrator
Jackson, MS, USA
VW tended to run full wirelooms and just leave the connections 'open' , like with the cd changers.
So yes, you PROBABLY just have to connect the parts and plug them in. Maybe use a VCDS to enable things.
Do these beetles have AC controls in them at all? I've never heard of NB w/o air, so I'm not sure what your control console looks like.
noR | me | Phrog
PHROG
Old 07-03-2009, 09:13 AM
02newmag's Avatar
Car: 2.0L 2002
it doesnt have the ac switch, just the air recirculation one. what about the temp dial on the dash, does that effect the temp of the ac or is that just for the blowers?
Need help to install cd player 55breeze New Member Forum 4 01-15-2009 07:54 PM
MBC DIY install TurboS-CR 1.8 Liter Turbo 19 06-03-2008 03:31 AM
'Vert armrest retrofit? nodialtone Styling Modifications 7 02-28-2008 08:04 PM
Install Help draco24433 2.0 Liter Gas 9 05-03-2007 02:17 AM
Pic's of a spare tire well sub install and Kick pannel speaker install Holland Car Audio 10 12-26-2006 04:19 AM
