The Haynes manual I have cautions that disconnecting and re-connecting the battery can cause the engine to run poorly, and require that some software parameters be reset by a dealer. Seems kind of crazy to me. Has anyone actually had this problem? I have to remove the alternate to get to the AC compressor, so I need to disconnect the battery.
Take a look at this too: Radio code
Egotism is the anesthetic that dulls the pain of stupidity -Leahy |
i had to change my batt. and now since i installed the new one the flashers blink. i think its the alarm or something. but i got the car used and didnt get the key fob. anyone know how to fix my problem. and do i need to get my comp done at the dealer??
My battery had connection issues due to bad wires. One week I noticed I could floor my accelerator and go nowhere and my engine was shifting at the wrong times with high RPMs.
I took it to my mechanic and he said that beetle do sometimes have this problem if you disconnect the battery. The computer "forgets" how to shift and accelerate.He cleaned my throttle body and some other stuff and magically my car "remembered" I'd be weary...but if something like this happens to you,you at least know what caused it and you can fix it! |
I got my NB and the batt come disconected and i have to get it towed to VW and have them reset the thortal control. and when they were thee i had them do a oil change and they noticed that i need a new $200 bat cover so i ended up paying about $370. so i wont disconect the bat unless i am at the dealer or use a cig lighter jumper i heard that that will keep what happened from happen
You got scammed. To reset the throttle you just leave your key in the accessories-on position for a few minutes and the throttle body will adapt by itself.
The battery cover had nothing to do with disconnecting the battery. You can open them easily without damaging anything. |
| Battery? | Mutato | 1.8 Liter Turbo | 1 | 02-09-2009 03:42 AM |
| Help - Need a new battery for my 1.8T! | 2naFish | Technical Modifications | 4 | 11-02-2008 03:24 PM |
| Help - Need new battery for my 1.8T! | 2naFish | 1.8 Liter Turbo | 0 | 10-14-2008 04:43 AM |
| disconnecting battery? | songsay | New Member Forum | 5 | 10-05-2008 11:24 PM |
| Disconnecting the MAF | vibelife | 1.8 Liter Turbo | 5 | 12-09-2007 09:45 PM |
