Exhaust woes! - NewBeetle.org Forums
Old 07-04-2009, 10:58 PM
Regina, SK, Canada
Car: Yellow '98 Beetle AEG + 01M
Default Exhaust woes!
Soo the Beetler decides to rot off it's tail pipes, then the Cat breaks loose inside...
$1800 for the exhaust system, or $800 for the converter. Turns out the 98 Beetle 2.0 has it's downpipe from manifold as a single piece into the Cat.
Will the exhaust from a Mk3 or Mk4 Golf/Jetta with a 2.0 work on the Beetler?
I need to replace the downpipe or full manifold, or the muff shops won't touch it.
Old 07-04-2009, 11:00 PM
Fowvay's Avatar
Moderation in Moderation
Berea, OH, USA
Yes the MKIV Golf exhaust will work the Jetta has a longer mid section but the front part will work just fine.
Check out the after market for the exhaust don't pay dealer prices.
Old 07-06-2009, 08:17 PM
Regina, SK, Canada
I'm looking, and I'm seeing alot more Mk3 packages that fit what I want. I want to keep the catalytic converter, and most of the mk4 headers delete the cat.
I read that the Mk4 headers from the AEG engines will fit the Mk3 heads, just there are some clearance issues. On the flip side they have the boss for the SAI, which after I rebuilt and reinforced the air pump, I really would like to keep. Keep the birds singing, I say.
Tr: 42 Draft Designs 3" TB Exhaust for stock Beetle Turbo S Exhaust (Chicago) r0nd3L Parts and Accessories 2 12-12-2008 11:10 PM
A/C woes... mgwerks Questions, Issues, Concerns, or Problems with the New Beetle 2 06-27-2007 07:15 AM
A/C Woes Formcar40 2.0 Liter Gas 2 02-28-2007 04:39 PM
Caractere/Remus exhaust sounds like factory...want exhaust with some sound phinsfan99 Technical Modifications 0 08-26-2006 02:23 PM
CEL Woes ImBuggin 2.0 Liter Gas 9 08-11-2006 10:11 PM
