Oil Cap question - NewBeetle.org Forums
Old 07-05-2009, 03:45 AM
Question Oil Cap question
Hey guys, I have a 2000 2.0 and the piece you screw the oil cap into moves when you tighten the oil cap. It has a hose coming out of it. Is it supposed to move at all??? I have had some oil on the engine block and I believe this is where its coming from. Any help would be greatly appreciated!
Old 07-06-2009, 12:40 AM
Yeah it's normal, you can probably replace a seal or something in there to firm it up.
pcv valve question and oil question a_magoo 1.8 Liter Turbo 3 10-07-2006 01:31 AM
p 0411 code question and coolant leak question.... bobbittle 1.8 Liter Turbo 5 06-12-2006 02:47 PM
