bleeding air out of cooling system - NewBeetle.org Forums
Old 08-03-2009, 04:36 AM
Car: vw beetle 1999 2,0 auto
Default bleeding air out of cooling system
can someone please tell me the correct way to bleed the air out of the cooling system..thanks
Old 08-03-2009, 06:28 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
Which cooling system are you talking about? Hell Ill post both
Engine cooling: keep the cap off the overflow tank and turn the car on. Turn the heat all the way up and the air to high. Fill the overflow tank as needed. It will take anywhere from 2-5 times to get it all out and even then I add a little more than the top to make up for little bubbles etc. Usualy after 10 minutes of running or so its enough for that particular run.
Air conditioning is easier. Just rent an air pump from autozone for free and attach it to the low side line input (where you put refrig to refil on the passenger side close to the radiator) and have it pull I think 24 pounds of pressure for 1 hour. Refil and your done. If you don't have an autozone but happen to have an air compressor you can get a venturi vacuum puller for like $10 at harbor freight or online.
Hope this helps!
Old 08-03-2009, 08:21 PM
Default thanks
thanks man i was refering to the cooling system..
Old 08-03-2009, 08:55 PM
Houston,
that still doesn't answer which cooling system
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Air in cooling system Babycar 2.0 Liter Gas 2 06-28-2008 05:52 PM
Fragile Cooling System 3lowdown Questions, Issues, Concerns, or Problems with the New Beetle 8 03-25-2008 01:09 PM
Air in cooling system? hillbilly4u 2.0 Liter Gas 2 12-03-2007 12:24 AM
cooling system problems robrobbyrobert 2.0 Liter Gas 1 09-03-2006 04:22 PM
Cooling System Thermostat Too Cold NB1.8T Technical Modifications 5 06-25-2006 06:17 PM
