Anti-Theft device preventing start of '99 2.0L New Beetle - NewBeetle.org Forums
Old 09-21-2009, 11:17 PM
Default Anti-Theft device preventing start of '99 2.0L New Beetle
My battery died and when i replaced the battery (and confirmed everything is connected fine with a load calc) the car didnt work. It starts up for 2 or 3 seconds, you can smell fuel and everything fires and then the computer (I am assuming) kills the engine. What can I do myself? what should I make sure the mechanic does if I cant fix it myself?
Old 09-22-2009, 12:05 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
I believe the engine wouldnt start if the alarm was going off so that might not be your problem.
any CEL's?
How is your oil level?
Old 09-22-2009, 12:50 AM
Default no CEL's and oil level is fine
there is no alarm going off it just wont let me start the car, it gets going and then immediately dies. No CEL's on that i can see in the 2 seconds it has power.
Old 09-22-2009, 01:52 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
there shouldn't be a factory immobilizer, so maybe an aftermarket alarm was previously installed?
however, that sounds like the vw immobilizer being tripped, who knows...you might have a REALLY late-build 99 with an immo (i've heard of it).
best to get it to vw, only they can unlock it unless your mechanic has vag-tacho or vcds.
Old 09-22-2009, 02:33 AM
Franco2112's Avatar
If you improperly installed the battery you might have shorted something. My battery was improperly installed and caused the fuel pump relay switch to fry. The dealership had to call the Big House to find out why it would not start. After 2 1/2 hours of Vag-Com and the Big House they finally found the problem. They stated that VW's are fickle to improperly installed batteries. I thought all cars had that issue? Guess not! Just VW's.
Try this. Disconnect battery NEG- first then POS-. Wait ten minutes. Reconnect the POS+ then the NEG-.
Old 09-22-2009, 03:18 AM
so there is no way to undo the immobilizer on my own...im going to have to pay for a tow too, so i would like to avoid it.
Old 09-22-2009, 03:57 AM
The Cheat's Avatar
where are you located? i have vag-tacho and vcds, and probably can un-trip it if you're in new england.
that is, if you do in fact have an immobilizer. is there a little car with a key in it lit up when all this is happening?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
key won't disable anti-theft system!?! jbh50 Questions, Issues, Concerns, or Problems with the New Beetle 1 08-08-2008 07:01 PM
TOTALLY screwed up my anti-theft bolts DruzeTito Questions, Issues, Concerns, or Problems with the New Beetle 5 04-17-2008 09:47 PM
Anti theft lug ackman 2.0 Liter Gas 3 09-10-2006 05:46 AM
battery dead & now anti-theft won't shut up eb747 Questions, Issues, Concerns, or Problems with the New Beetle 3 11-27-2005 07:43 AM
Beetle Anti Theft alarm comes on by itself maz52 Technical Modifications 6 10-25-2005 04:31 AM
