Hi Everyone... I've been searching all kinds of Beetle sites on the internet with no luck as to what it takes to remove the crankshaft sensor on a 2000 Beetle 2.0L gas engine. I have located it but HAVE NO IDEA ON HOW TO GET TO IT
so I can replace it with a new one. It seems impossible to access it. Is there some sort of special technique or tool needed? Can this repair be done at home or do I need to bring it to a mechanic to replace it?Any help would be appreciated, I am definitely starting to lose it! ![]() David |
this info was taken from the vortex archives
Crankshaft position/speed sensor is an induction coil that goes into a hole in the side of the block and monitors a notch or bump on the crank for crankshaft position. It is held in by one small bolt....unfortunately, you have to pull the front motor mount bracket so you need to pull starter motor mount etc. to get it out of the block. Not a 5min job, but doable for anyone who knows his/her way around a basic tool box. Need to support engine while the front mount is off...other than than straight forward hour or so...$200 (after taxes) not bad pay for an hour on a Saturday morn I'd say. good luck...it was found in the 2.0 engine forum and should be right..i'll dig up my books and double check it later but that sounds legit..what makes you sure that its that sensor? from reading on the tex it looked like some other things could cause that code to be thrown as well...might be worth it to pick up a bentley manual or haynes manual(cheaper, more pictures, easier to obtain) if you were local i'd do it for you.
Jim ![]() sold1998 silver arrow 2.0 5 speed- 1997 GTi VR6..its cliche http://rustisnotacrime.com |
Thanks Jim, now I understand the problem with getting to it. Thanks so much for replying with all that info, I really appreciate your efforts! Before I go replacing anything... probably should test it with a volt meter? From what I've been reading and the info I've been gathering that was the next part I wanted to replace. I can't believe the placement behind that part?
The problem is my car starts fine and runs fine for about 20 minutes, then it just shuts off with no warning and I coast to a safe place off the road. Within a half hour or so, the car starts fine until the same thing happens again. Crankshaft Sensor sounded like it could be failing giving a false reading to the ECU. Any thoughts? David |
should throw off a cel if it is in fact bad. another problem could be a clogged cat.
you haven't told us if you've isolated the problem via an obd2-compatible scanner. you're fairly local to me (2 hours away), i'd do it for $20 and a #2 no ranch at arby's if the cps is the issue.
You probably won't believe this but I was able to remove the crankshaft sensor WITHOUT removing anything else. It helps to be as flexible as Gumby... only took a few days and a little pain. Anyways, thank you all for your input... I really appreciate the help and enthusiasm.
That was exactly what the problem was and it's running beautiful once again. You guys saved me a lot of aggravation as well as a lot of money! Thanks so much, David |
Did you happen to take any pictures? A step by step how-to would, I'm sure, be appreciated by many.
'02 & '05 Acura RSX Dodge Cummins, Ford Ranger M151 Ford "Drive less, worry more. It's cheaper." Last edited by cep; 10-15-2009 at 01:55 AM.. |
hey my car has the same problem. it shuts off after idling for 21 min or so. I've located the crankshaft sensor and removed the nut, but can't manage to pull it out. It turns in its socket easily enough. Is there a trick to it?
Yeah, that's the trouble with replacing this little bugger. Although there's limited space to work (and that's being generous) you've got to find a pair of pliers to grab hold of it and pull it out. No trick other than that.
hey everyone, we managed to pull out the sensor. it wasn't too hard to get my hand up there when we put the car up on jack stands. it was wet inside and the contact point was covered in grime. we are looking to buy a replacement but notice a big price discrepancy between brands ($8 to $110). i'm inclined to buy the cheap one by the brand "Replacement". does anyone here have an opinion on this? the links to the two parts are below.
1998-2001 Volkswagen Beetle Crankshaft Position Sensor - Replacement 1998-2001 Volkswagen Beetle Crankshaft Position Sensor - Standard |
hey all, i have a 99 beetle.. with the same problem..
i took the codes and according to the book it says my cam sensor is malfunctioning... but you all say that its the crank sensor... my car will run for about five minutes or so and then just stop and wont start for a half hour or so.. which is exactly how you desribed your problem.. hmmm well im going with you all especially since its much easier to change. thanks this car has many other problems as well ill check back daily here to see if anyone gets on here again or just email me at borntwown@aol.com if anyone knows about these cars ... i would appreciate any help i can get.. thanks so much kevin |
hey kevin
i've read that the code that often comes up is the camshaft sensor code, when the part thats acutally not working is the crankshaft sensor. i think my car was giving the same cam code as yours. i bought my cranshaft sensor discounted online for $7. i'd recommend trying it, escpecially since the part can be found for so cheap. good luck! elisabeth |
After reading this thread, I think Moe have the same issue.
Just where is the crankshaft sensor located? I've heard that it's under the oil filter, hidden under the timing belt cover, next to a pulley ![]() Can someone please tell me exactly where it's located on a 2.0... Thanks ![]() |
replaced the sensor i was hoping it would run better but no change.car still stumbles,surges,and stalls,at not on a routine basis.it does it at idle or at a stop light.weird and scary any other suggestions
i'm not an expert by any means, but this what i would check
i would check to make sure your battery connections are all tight and free of corrosion your fuel pump might be giving out. with my car it seemed like an electrical problem because it was so quiet. if the car is studdering that sounds mechanical to me. you can try changing the fuel filter. it its clogged that could be taxing the pump. |
| Camshaft Position Sensor P0340 code | mikesierra46 | 1.8 Liter Turbo | 1 | 07-04-2009 01:02 AM |
| Cam Position Sensor | mseifert_99 | 1.8 Liter Turbo | 4 | 07-03-2009 06:23 PM |
| Cam Position Sensor, timing belt and other work | Papa Gino | 2.0 Liter Gas | 1 | 04-13-2009 02:17 PM |
| Randomly won't start - crankshaft position sensor? | mosesbaca | 2.0 Liter Gas | 3 | 11-14-2007 09:53 PM |
| camshaft position sensor - CEL | sequoiagrapeboy | 2.0 Liter Gas | 3 | 02-16-2006 01:16 AM |
