I still have my appointment for the 26th to have the Frigi-Clean stuff blown in my AC evap case.
Me (Erin) ~ My car (Curby)
I'm kinda surprised the Frigi stuff didn't work, to be honest. |
Now that the weather is getting wet/snow, the smell is coming back. Anyone have any idea what part I could replace to get rid of this smell? |
You might need to have your AC condensor cleaned. The evaporator coils can become nasty over time and bacteria can grow in there. I don't know how much it costs or even who will do it.. but I know it is a known problem with cars that have AC and age.
I used to own a 2001 VW Beetle GLS. It was Silver. I done a carfax report and found out it's now located in Atlanta, GA! Do you have my old Beetle?! I'd love to chat with you! |
BG Products, Inc. I did the Frigi-Clean stuff and the mechanic would have injected it into the evaporator case. |
So there are several products on that web page - two of which are cleaners and yes, they spray into the evap case. Did you ever check to see if the drain hole for the evaporator was plugged? I don't see where you replied to my previous post on this. If the hole is plugged, no amount of cleaner or drying out the evap case will solve your problem. |
I have heard that if you straighten out a coat hanger and GENTLY slide it into the tubing, if there is a clog, this will dislodge it. But be careful not to damage something. Proceed at your own risk though... |
There shouldn't be any draining to the inside of the car at all. This drain should be on the outside of the car. Did you see this post by the guy?
:Found my little drain line. it's under the dash on the pasenger side of the car. it's about 1/2" in diameter and goes out through the firewall. Mine wasn't plugged, but there's the info for those of you who need it... " Posted on Aug 18, 2003. Another person commented: "I am telling you all you have to do is remove the little flap that covers the drip tube at the fire wall. I did and ever since I don't get any smell. That flap traps water in the drain and it grows mildew." and another.... "You're into the right place. I hit the insulation too and shuddered thinking this can't be right, but I dug a small screwdriver through it and lifted up the flap. Sure enough, there is a rubber boot under it. With my arm in this very akward position, I was wondering how I was going to cut this thing off. Instead I grabbed on to it and gave it a firm tug. It came off in my hand but I let go of it at the same time and haven't been able to find it, so I still don't know what it looks like. Haven't had it off long enough to report any results. Good Luck. " Last edited by jermnc77; 02-23-2010 at 05:51 AM.. |
Just follow safety precautions! |
A bad heater core would give you that wonderful sweet smell of coolant, not the smell that callisto is getting. I know what that smell is. I get it in mine sometimes. But it does go away with use. I get the smell more when its raining and such. Definitely seems to be a musty odor.
I want to keep Curby. This smell needs to go! However, I also need for it to warm up so I can get it properly diagnosed when it's good and stinky. ![]() |
Well, here is the thing if it is what is considered as environmental smell it will dissipate with time.
If it is a musty smell, your in cabin air filter could be the source and getting a new one, could fix the issue. From what I understand though, they arent easy to change. They are shoved under the dashboard. |
Nah they aren't a problem to change. A few screws and pop off the dash cover on the passenger side. I've changed mine, doesn't help. Still get some must. But again, mine goes away after the a/c is used for a bit. Usually happens after sitting and not being used.
| This Stinks! | tippitover | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 08-24-2009 03:56 AM |
| no heat inside my 2002 2.0 Beetle | inkman27 | 2.0 Liter Gas | 2 | 05-08-2009 06:58 PM |
| Canned Heat Radio-Controlled Yellow Beetle | BlueMartian | Miscellaneous Hoo-Ha Archive | 5 | 01-04-2007 03:50 AM |
| Stop Heat from coming into cabin | yellow1.8T | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 07-16-2006 05:27 AM |
| A/C stinks | Paladin | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 11-07-2005 12:30 AM |
