Really? Thats interesting.
Its good to use the A/C every once in awhile. It keeps the grommets/seals lubricated with PAG Oil, so they dont erode. I'll have to look at the procedure again for the in cabin air filter. It looked like a bitch to fix. Maybe I confused myself. |
Me (Erin) ~ My car (Curby)
I know the weather is terrible but on a day when it is clear you could drive up a driveway with curb's and pop the one side up(passenger sd ) then you would be able to access it...I'll see if i have any pic's in the Bently to help you out in finding it... I had the same nasty smell but was fixed by me cleaning the cabin air filter box out with Lysol Wipes and new filter....My condensate drain was clear and clean....In a northern climate i would not remove the boot as that would cause all kinds of other problems. The best way to clean the drain is to remove the rubber on the drain carefully as not to damadge it and vacuum it out and put the rubber back on and your all set...
When you make a post, scroll down and look for "manage attachments". Click on that button. You will then see a screen and a place where you can upload a picture from your computer. Click on "browse" find and attach your picture. Click on "upload". The "close this window". Picture should then be attached to your post.
Thought i'd try again....And bingo...Here you go i guess my note to the administrator did the trick...Thank's
Let me know if you need any more help with this stinky situation..lol JimLast edited by Canadianbugin; 08-05-2010 at 11:06 AM.. |
| This Stinks! | tippitover | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 08-24-2009 03:56 AM |
| no heat inside my 2002 2.0 Beetle | inkman27 | 2.0 Liter Gas | 2 | 05-08-2009 06:58 PM |
| Canned Heat Radio-Controlled Yellow Beetle | BlueMartian | Miscellaneous Hoo-Ha Archive | 5 | 01-04-2007 03:50 AM |
| Stop Heat from coming into cabin | yellow1.8T | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 07-16-2006 05:27 AM |
| A/C stinks | Paladin | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 11-07-2005 12:30 AM |
