I'm not using the Lysol right away. And, it's an eight-year old car...how much worse can I make it? ![]()
Me (Erin) ~ My car (Curby)
Lot's if it clogs-up the heatercore and have to have it replaced... To replace the heatercore most of the dash has to be removed...So your choice... If this was my car i would vacuum out the condensation drain and wipe out(with Lysol Wipes) all the cabin airbox where the filter goes. I had the same problem on my 98 NB and did all the above including the filter and bingo no smell and have not had the problem since...
![]() Now to go find a how-to on removing that top dash piece... |
I can guide you though that......1. Push the centre section of the top of the dash towards the windshield and it will come out. 2. Now at the front of the pannel you just removed you'll see two Torx screws..remove them and slide the side Pannel toward the drivers side(will just side out in your hand) and below that you'll see the top of the cabin filter box.3.Remove the screws from the top of the airbox and lift off and remove the filter. Now you'll be able to wipe it all out with the Lysol wipes. If you see anything like leaves or anything around there just vacuum it out then do the wipes.... If the Bentley had a good picture i 'd post it but the one i found would only confuse you as it does not have all the pieces in the picture.... Let me know if you need more info but it's a easy thing to take apart....
Nothing beats seeing it with your own eyes instead of in a picture....Then you'll understand what i was telling you before...I feel for ya as my car smelled like a musty barnyard when i bought her it was nasty....
Well, the smell still remains. No smell when heat/air isn't on, but the smell is def still there when I turn it on. Worse when it rains.
I don't smell it when the recirc is on, only when the air is coming from outside. So what part do I have to replace to have this fixed? I've had it. If I can't get this fixed, the Beetle goes. I'm tired of this problem. ![]() |
You should be able to get to this from the engine compartment. You'll have to remove the plastic shroud at the base of the windshield. I've never done this on a Beetle so don't know whats involved. Worst case - you may have to tear out part of your dash to get to all the air chambers to clean the junk out. |
mine STUNK like wet dog when I got my car...
took the top panel of the dash off to change the cabin filter and about puked at all the stuff i found in there and the smell that was in there too. the filter was no longer a filter. it was a breeding ground for nasty. there were wet leaves all over the place, and just gunky crap... took a shop vac and some cleaner to it. replaced the filter. sprayed it all down with some disinfectant, and slapped it all back together... took about a week of running the A/C to get the smell totally out of the duct work, but it is gone... Like you, if I turned the recirc on, it seemed to get less noticeable. Good Luck, Erin! |
| This Stinks! | tippitover | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 08-24-2009 02:56 AM |
| no heat inside my 2002 2.0 Beetle | inkman27 | 2.0 Liter Gas | 2 | 05-08-2009 05:58 PM |
| Canned Heat Radio-Controlled Yellow Beetle | BlueMartian | Miscellaneous Hoo-Ha Archive | 5 | 01-04-2007 02:50 AM |
| Stop Heat from coming into cabin | yellow1.8T | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 07-16-2006 04:27 AM |
| A/C stinks | Paladin | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 11-06-2005 11:30 PM |
