Curby is now eight years old and as of a few weeks ago, there's an awful smell coming from the heat / A/C and I can't seem to get rid of it. Mechanic replaced the cabin air filter and blew something into the vents, but the smell remains. It's a very musty, mold-like smell. It reeks. Also seems to have picked up my last air-freshener, too. So, it's musty-smelling air-freshener. LOL
Smell is only apparent when heat/air is on. I've read about this stuff: Buy Frigi-Clean® and Frigi-Fresh® | BG Frigi-Clean® and Frigi-Fresh® AC products | Frigi-Clean® and Frigi-Fresh® But don't know if I can drill a hole in whatever I need to drill a hole in. I need help! I'm about ready to chuck Curby in the river! He STINKS! Any advice? Anyone rid their car of this smell?
Me (Erin) ~ My car (Curby)
I just recently changed out the cabin filter on my bride's NB....she also made mention of the "funk"...... what I found was lotsa leaves and debris around the filter.....if this gets damp, it will begin to smell like a compost heap in short order...I vacuumed out the debris....no mo funk...
i have also heard that condensation can build on on the evap causing an odor as well. this info came from a haynes manual that i have. but the cabin filter is the best bet. had the same build up vac'd it all out and changed the filter smells great!
"Semper Fortis" |
1. Turn recirculation switch to "outside air" position 2. Turn off A/C compressor 3. Turn fan on HIGH If you don't want to start the process a mile or 2 from your stopping point you could do it just before shutting off the engine. But just make sure to run the fan (step 3) for about 5 minutes before shutting your engine off. All cars with A/C are susceptible to the "stink." Some more than others. The Beetle, I have found, is VERY susceptible. If you still have the "stink" then you need to start the process earlier (try 3 miles before stopping) or run the fan longer than 5 minutes. I guarantee this process will eliminate the problem. Been doing it for years. |
Buy Frigi-Clean® and Frigi-Fresh® | BG Frigi-Clean® and Frigi-Fresh® AC products | Frigi-Clean® and Frigi-Fresh® So, in the meantime, when you say the "outside air position", do you mean that button to the right of the AC? So, that button ON, AC button OFF? |
How long you actually run the fan or how far down the road you start the process (it's an either/or choice) will depend on outside weather conditions. If you still get the stink then run the fan longer or start the process earlier before reaching your destination. |
Again, thank you! |
Good point. All the way "full cold". You want ALL the incoming air blowing thru the evaporator. Moving the temp toward hot will divert part of the air thru the heater core - doing nothing to help correct this stink problem.
My wife also had a very strong crayon smell in her 2004 Beetle. Come to find out when it is very hot outside here in AZ 105F plus, the floor mats are letting off a weird crayon type smell. Where is this cabin filter located? I'd like to check that.
There are many threads here on the .org about it. It comes from either an adhesive or plastic under the floor. You're just going to need to get used to that smell. ![]() |
Edit 10/9/09: Wait - why did you take a "very cold ride" to work? If you don't need A/C why did you turn it on? You're just making the problem worse. Oh, and another tip - make sure your evap case drain hole isn't obstructed. That will cause water to "pool" in the evap case and creates a worse problem - in which case the procedure I recommended above ain't gonna work. Last edited by salsa-man; 10-09-2009 at 01:54 PM.. |
I think I've read somewhere in another thread that the smell is coming from the Beeswax used to waterproof the inside of the doors and body panels. I've seen the the stuff melt (in the Texas heat) and drip out of the drain holes in the bottom of the door onto the side rocker panels.
| This Stinks! | tippitover | Questions, Issues, Concerns, or Problems with the New Beetle | 13 | 08-24-2009 02:56 AM |
| no heat inside my 2002 2.0 Beetle | inkman27 | 2.0 Liter Gas | 2 | 05-08-2009 05:58 PM |
| Canned Heat Radio-Controlled Yellow Beetle | BlueMartian | Miscellaneous Hoo-Ha Archive | 5 | 01-04-2007 02:50 AM |
| Stop Heat from coming into cabin | yellow1.8T | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 07-16-2006 04:27 AM |
| A/C stinks | Paladin | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 11-06-2005 11:30 PM |
