Please Help! The engine has very little power and shaking. - NewBeetle.org Forums
Old 10-25-2009, 03:02 PM
Default Please Help! The engine has very little power and shaking.
Hi, My girlfriend started her car yesterday and the engine is shaking. The car has very little power. I ran the codes and it has four codes: P0300(multiple Cyl misfire, P0301(Cyl misfire), P0302(Cyl 2 misfire) and P0303(Cyl 3 misfire). Does anyone have any ideas? Thanks so much!
Old 10-25-2009, 03:18 PM
Have the spark plugs/wires been changed at all?
Old 10-25-2009, 03:36 PM
Hi, I haven't changed the wires or plug yet. It all happen when the car started up, so i can't believe it would be the wires and plugs would all fail at the same time. I think one could fail but three of them. Thanks
Old 10-25-2009, 03:49 PM
How many miles on the car?
Old 10-25-2009, 03:58 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
sounds like the ignition system needs an overhaul.
get ngk plugs and wires (or nothing else, everything else, is in fact, junk), and install them.
check your injector cycles.
sounds like a tuneup, but could be fueling-related as well.
of course, the belt could have jumped a tooth...
Old 10-25-2009, 04:22 PM
Hi, there is only 39K on the car and is a 2002
Old 10-25-2009, 04:43 PM
This is really weird, I started her car today and everything is run fine. I took on a test drive and it is running normal. It was raining yesterday and I wonder if that had anythin to do with it.
Old 10-25-2009, 04:52 PM
angelworks's Avatar
Write it like it's hot!
If I can make it there--NY baby, USA
Car: 98 Red 2.0 ,5 speed -70K
Coil packs? They give intermittent as they start to go and moisture will make them do as you described as they are going.
Drive it like you mean it!
My Greenie Blog
Body in the United States/ Heart in Ireland ~~~ Princess Poppy 1998 5 spd Red
Old 10-25-2009, 05:30 PM
Default Maybe A Loose Connection
I think that was all that was wrong with my 2005 beetle but I left if with the shop anyways thinking they would check it out. Now I realize that they just use the parts of a new customer to fix the previous customer's car.
Jiggle the electrical connections. I had just bottomed out when I hit a dip when my problems started.
Old 10-25-2009, 07:32 PM
Mr Maynard's Avatar
Beetle Loving Gamer
Swansea, IL, USA
Car: 2000 GLS
This happened EXACTLY to my Mk3 Golf years ago. When the weather was Moist, it made the wires short thus starting Misfires in Cyl 1 and 3.
Came down to Wires, Spark Plugs, and Distributor Cap. Its rather odd it your beetle has 33K miles on it. but I'll put my bet down on that.
Old 10-25-2009, 07:33 PM
I would start with spark plugs.
Old 10-25-2009, 09:36 PM
Thanks everyone for your help!
Engine misfire, studder at idle/low gear, AC power outlets gone, door chime faulty... lokyee Questions, Issues, Concerns, or Problems with the New Beetle 3 09-28-2009 08:47 PM
Power shift engine hiccup? Genifer Teal Questions, Issues, Concerns, or Problems with the New Beetle 17 07-13-2009 07:43 AM
Help!! Washed Engine Now Shaking! heatherm Questions, Issues, Concerns, or Problems with the New Beetle 5 12-22-2007 09:29 AM
motor shaking in the morning denisse 2.0 Liter Gas 15 06-07-2007 03:47 AM
CEL plus violent shaking at idle Katiebug Questions, Issues, Concerns, or Problems with the New Beetle 16 02-14-2006 06:04 PM
