P0411 and P0422 Need Help - NewBeetle.org Forums
Old 10-31-2009, 03:35 AM
Default P0411 and P0422 Need Help
I want to clear these codes and keep them cleared. I checked and replaced the vac lines to the purge valve and cant find any leaking lines. Finally decided to remove the Secondary Air Injection Pump. It doesnt run and I really dont need it. I blocked the lines. Still getting these two codes after I clear all codes. Is there a way to trick the ECU or is there someting else that I can do?
Thanks
Old 10-31-2009, 03:43 AM
BUGSTUFF's Avatar
New Beetle Accessories
Bartlett, IL, USA
If the pump is unplugged, the code will not clear.
I heard there is a way to use the VAG-COM to code your ECU/ECM for the NB's that were not equipped with SAIP's.
Good luck!!!
Kirk & Pam & "Key Lime"
Northeast IL VW Association
Volkswagen Club of America
Old 11-01-2009, 09:01 PM
Mr Maynard's Avatar
Beetle Loving Gamer
Swansea, IL, USA
Car: 2000 GLS
There is, My MK3 gold had the Secondary Pump, but the Pipe cracked. Threw the Engine light on all the time.
I had them before, but this was a while ago, You'll need to snoop around and get the codes. Check vwvortex
Tags
air pump , codes , leaks , p4011 , p4022
P0422 CEL code rob11g Questions, Issues, Concerns, or Problems with the New Beetle 1 03-14-2008 01:49 AM
p0422, 02 sensors,cat? barrabiuri Questions, Issues, Concerns, or Problems with the New Beetle 12 07-05-2007 04:29 PM
P0422 Code, need help please rob11g Questions, Issues, Concerns, or Problems with the New Beetle 4 05-09-2007 11:56 AM
Help! What does code P0422 mean? Lime Green Bug Questions, Issues, Concerns, or Problems with the New Beetle 2 07-28-2006 08:11 AM
