Trunk won't close - NewBeetle.org Forums
Old 12-09-2009, 12:46 AM
Genesis's Avatar
Virginia Beach, VA, USA
Car: 2000 GLS
Thumbs down Trunk won't close
My son drove my 2000 beetle to work today. He returned home to tell me that hatch/trunk won't close. Checked the latch and it won't catch on the striker. Has anyone else experienced this problem.
Old 12-09-2009, 01:19 AM
Beetlecup's Avatar
senior member
Tampa / St. Petersburg, FL, USA
Car: 2003 Turbo S
Yes this is a problem with the new beetle.
You can adjust the bump stoppers on the trunk. They look like black rubber and sit on the body.
You can also adjust the metal truck latch which is down bummer side. Loosen up those bolts and move very so slightly.
Old 12-09-2009, 02:28 AM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
Has it been washed or rained on for some time??Mine too has a hard time latching and sometimes won't latch at all after its been soaked.Its due to a leaky third brake light.
That may or may not be the case,just throwin it out there for ya
Old 12-10-2009, 05:06 AM
Genesis's Avatar
Car: 2000 GLS
It has been raining. The trunk has been leaking lately. I had the Sunroof drain tubes cleaned two weeks ago, thinking that it would fix the problem. Thanks for the incite.
Old 12-10-2009, 08:50 AM
Before you go dismantling everything, does your boot lock allow you to open it with the key?
If it does, insert your key turn it left then right, and close the boot. This should reset the boot mech and everything should work properly
Always works on our '00 NB
Our cars:
2012 Beetle Design 2.0TDI (140BHP) (UK car)
2012 Nissan Juke 1.5dci Acenta Sport (UK car)
Old 12-10-2009, 03:22 PM
VW Junky
I've never heard of that method,it has been pouring lately and my hatch has been acting up,so ill give it a shot,THANK YOU!!!I hate having to slam my hatch...
Old 12-10-2009, 04:58 PM
VW Junky
I tried the key method and it worked..This will help out many in need of a solution...at least until they get that brake light sealed up again
Old 12-10-2009, 07:56 PM
callisto9's Avatar
Good-bye Curby...
Bettendorf, IA, USA
Car: '08 Scion xB
I had the same problem for about a year. It would latch, but only partially. I would have to open and slam it shuts several times before it would catch or just push down on it while it was partially latched.
I finally got the latch replaced this year and now it takes two "unlocks" to open.
Me (Erin) ~ My car (Curby)
(o\_vw_/o) Beetles rule!
There's no apostrophe before an 's' when you're talking about the plural version of a word. "I took some neat photo's!" is NOT correct.
Old 12-10-2009, 08:35 PM
Try the reset method I stated above - you never know it might sort your problem out
Old 12-10-2009, 08:38 PM
callisto9's Avatar
Good-bye Curby...
Bettendorf, IA, USA
Car: '08 Scion xB
Will do. Thanks for the tip.
Old 12-12-2009, 04:18 PM
jhicken's Avatar
Flagtown, NJ, USA
Car: 1999 New Beetle GLS
I have the same issue, but it normally happens only when the temps drop. I use the key and it works every time. Another solution is after the failed attempt, instead of opening it up and trying to slam it again, just put both your hands on each side of the lower edge of the lid and firmly push down. It works every time.
-jeffrey
Old 12-13-2009, 05:43 AM
callisto9's Avatar
Good-bye Curby...
Bettendorf, IA, USA
Car: '08 Scion xB
-jeffrey
Yep. I wish I had figured that one out 2 years ago instead of 6 mos. ago.
Old 12-13-2009, 09:47 AM
Default My Hatch Problem
I flip the open lever on the driver's door and go to the trunk to pull it open only to have to go back to the driver's door to flip the open lever again.
I don't know why it won't unlatch on the first try.
Old 12-13-2009, 07:48 PM
Thats due to the adjustment of the things that make the bootlid 'pop' if they aren't adjusted properly it wont always pop
Old 12-13-2009, 09:22 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Weak/cold gas struts on the lid will also cause that, it will pop some but still be held by the latch...
Cheers
Simon
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
trunk will not close! CHEEZYSPAM Questions, Issues, Concerns, or Problems with the New Beetle 11 10-18-2012 05:12 PM
Trunk doesn't close. ninsei Questions, Issues, Concerns, or Problems with the New Beetle 5 11-05-2008 03:08 AM
What's the magic word to close the trunk tightly??? ChrysalisUnfurled Questions, Issues, Concerns, or Problems with the New Beetle 10 03-31-2007 10:31 AM
My trunk won't close stsean Questions, Issues, Concerns, or Problems with the New Beetle 4 01-15-2007 03:45 AM
cant close the trunk eidurth The New Beetle Experience 11 04-14-2006 09:34 PM
