Two front power outlet not working - NewBeetle.org Forums
Old 12-19-2009, 05:56 PM
LuvBug122593's Avatar
Jessica's Dad
Bel Alton, MD, USA
Car: Black 2002 GLS 2.0L 4-Auto
Default Two front power outlet not working
My 2 front power outlets are not working, the fuse (41 yellow 20amp) is good. But my trunk power outlet is working. Hope someone can give me an idea on where to look.
Thanks in advance
LuvBug122593
Jessica's Dad
Noel's Bug Douglas
Old 12-19-2009, 06:01 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
anything else not working?
might be a good starting point, many accessories are daisy-chained into one-another.
Old 12-19-2009, 07:01 PM
digitalputty's Avatar
Where is home ....
Los Angeles, CA, USA
Car: 2013 Red Fiat 500 Abarth
The only one that works in my car is the front one that's also the cigarette lighter. :/
Old 12-19-2009, 07:04 PM
Jessica's Dad
Bel Alton, MD, USA
Everything else appears to be working. Are there any fuses in the engine compartment I should look at?
Old 12-19-2009, 08:39 PM
Default Power Outlets
I hope you're just talking about the 12v outlets because I just bought an inverter to give me 110v and am looking for a place to mount it. If this car already has it though I can put the inverter in another car.
It doesn't look like I can mount it anywhere because the cables from the inverter are so short. I'll have to have the car parked with the hood open. My neighbor had a truck with his computer powered up in the vehicle and would be printing paychecks on the way to the construction site he was the contractor at.
Old 12-19-2009, 09:08 PM
The Cheat's Avatar
threadjack!
op, you'd be very surprised...check EVERYTHING out.
Old 12-19-2009, 09:30 PM
Default Newbeetle Specs
This site gives all the specs for the Newbeetle and lists only the 12v outlets: Used Volkswagen New Beetle - VW Certified Used 2005 New Beetle - VW.com
Old 12-22-2009, 01:07 AM
Jessica's Dad
Bel Alton, MD, USA
Does anybody have the wiring diagram for a 2002 NB GLS. What I want to know if all of the 12VDC are on the same fuse?
Thanks is advance
Old 12-28-2009, 02:03 AM
Jessica's Dad
Bel Alton, MD, USA
Default Problem Fixed
Took the Beetle to the dealership to get a new key and remote programed. Asked them to look at the 12VDC outlets. Tech found a blown 15amp fuse not #41 but the one to the left of it. I guess you need to pull all the fuses to make sure you find the right one.
Old 12-28-2009, 07:09 AM
The Cheat's Avatar
told ya.
sometimes circuits are shared, like if your heated seats don't work and neither do the heated mirrors or rear defrost, check fuse 1 first as the heated stuff does feed through the mirrors first.
Old 10-22-2016, 05:57 PM
Is this a common issue?
I have a brand new 2016 Beetle 1.9 Turbo
The power outlet at front - both cigarette lighter and USB does not appear to be outputting enough power to charge my Samsung phone
Does anyone have any ideas?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
the 2 front power outlets are not working playstation3 2.0 Liter Gas 3 11-30-2009 09:10 PM
Car audio won't work after using power outlet im_twinkling Car Audio 3 02-13-2009 05:11 PM
Rear Power Outlet Flopped Open glastarguy Questions, Issues, Concerns, or Problems with the New Beetle 1 01-28-2007 02:22 PM
blown power outlet fuse? rayxray18 Questions, Issues, Concerns, or Problems with the New Beetle 0 03-15-2006 10:00 PM
Always ON DC Power outlet. neko Technical Modifications 7 10-11-2005 12:54 PM
