how do you replace the camshaft sensor - NewBeetle.org Forums
Old 12-27-2009, 04:49 AM
Thumbs down how do you replace the camshaft sensor
Hi,
I just bought a used 2000 buggy and drove it for about 3 month and then the light engine came on. I didn't know what happened so i took it to the shop to get it checked. The guy said that i need to replace the camshaft sensor. Can somebody tell me how i can fix it. Also some pictures with instructions on it would be really helpful.
-Thanks
Old 01-01-2010, 06:29 PM
Default Camshaft Position Sensor - check
Seems like you would want to double check to see if the camshaft position sensor is really bad.
Haynes VW 1998-2005 Repair Manual says:
"The camsahft position sensor, ..., determines the ignition timing and fuel injection synchronization on each cylinder.
Check: Performing the folling test will set a diagnostic trouble code and illuminate the Check Engine Light. Clear thediagnostic trouble code after performing the tests and making the necessary repairs.
The camshaft position sensor is located at the front of the cylinder head under the timing belt cover. On 2.0L models, the camshaft position sensor is located behind the camshaft sprocket and is equipped with a pigtail lead and a remote connector. On 1.8L turbo models, the camshaft position sensor is located at the front of the intake camshaft. check the terminals in the connector and the wires leading to the sensor for looseness and breaks. Repair as required.
Before checking the camshaft position sensor, check the voltage supply and ground circuits from the ECM. Dosconnect the electrical connector from the camshaft position sensor and connect a voltmeter to terminals 1 and 3 at the harness connector from the camshaft position sensor and connect a voltmeter to terminals 1 and 3 at the harness connector. Turn the ignition key On - the voltage should read approximately 5.0 volts. If the voltage is incorrect, check the wiring from the camshaft position sensor to the ECM. If the circuits are good, have the ECM checked at a dealer service department or other properly equipped repair facility.
To check the camshaft position sensor operation, reconnect hte connector to the camshaft position sensor and using a suitable probe, backprobe terminal no. 2 of the camshaft position sensor connector. Connect the positive lead of a voltmeter to the probe and the negative lead to a good engine ground point. Turn the ignition key On. Rotate the engine slowly with a breaker bar and socket attached to the crankshaft pulley center bolt while watching the meter. The voltage should fluctuate between zero volts and 10.0 volts as the vanes in the reluctor wheel past the sensor. If the test results are incorrect, replace the camshaft position sensor. Note: Rotate the engine slowly through at least two complete revolutions. Removing the spark plugs from the engine will make the crankshaft much easier to turn. Warning: If you remove the spark plugs, unplug the primary (low voltage) electrical connector(s) from the ignition coil(s) to disable the ignition system.
Old 01-02-2010, 12:04 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
if you got code p0341, then yes, the cam sensor is the culprit.
to replace, it's fairly straightforward; if you can do the belt on your own, it's only another 30 minutes to replace it.
i have a DIY in progress on the timing belt.
Old 01-02-2010, 08:42 PM
Default To Replace It
Now that you're ready to replace it.
  1. Remove the timing belt and the camshaft sprocket
  2. Remove the timing belt rear cover. disconnect the camshaft position sensor electrical connector and detach the electrical connector from the bracket.
  3. Remove the camshaft position sensor mounting bolt and remove the sensor from the cylinder head.
  4. Installation is the reverse of removal.
Have fun!
Old 07-04-2010, 08:04 AM
antelope (sacramento), CA,
Car: 1998 beetle
thanks for the helpful info
Old 08-31-2010, 01:47 AM
Thumbs up Great help
Hi! I know this post is kinda old, but I really want to thank you all for the informative post. I recently bought a camshaft position sensor online through google and was really wondering on how to install it in my beettle. Thanks, for this thread.
Camshaft Position Sensor P0340 code mikesierra46 1.8 Liter Turbo 1 07-04-2009 01:02 AM
Camshaft Sensor Error Peter T 1.8 Liter Turbo 0 05-03-2009 01:31 PM
Camshaft sensor location on 99 beetle 2.0L DonM77 2.0 Liter Gas 6 03-03-2009 07:46 PM
camshaft sensor / engine wiring harness megantbs Questions, Issues, Concerns, or Problems with the New Beetle 1 01-21-2007 04:10 AM
camshaft position sensor - CEL sequoiagrapeboy 2.0 Liter Gas 3 02-16-2006 01:16 AM
