HiLiter Has Issues - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 03-04-2011, 10:45 AM
huck731's Avatar
turbo
Fort Atkinson, WI, WI, USA
Car: black '99 2.0 5spd Retro, 1971 super beetle
I normally get that much when it is really cold out side, when spring/summer comes around it disapears. As for the SAP, I think that depends on where in the us the car was originally designed to be sold such as cali or any other state with stricter emmissions standards. My NB does not have one either.
Driver, your New Beetle will see you now.
black '99 5speed "Retro" - Bridgette
kuboto orange '71 super beetle
Bridgette
Huck731
  #22 (permalink)
Old 03-05-2011, 04:35 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Ordered the parts from German Auto Parts dot COM ...
VW Oxygen Forward Sensor $ 88.45
VW Spark Plug, NGK BKUR6ET-1 $6.15 x 4 $ 24.60
VW Ignition Wire Set $ 52.91
VW Ignition Coil Pack w/Module $ 72.45
Shipping $ 15.93
Order Total: $ 254.34
Just for comparison purposes, here is what a Nashville Dealer quoted...
Parts $510, Labor $387, TN Taxes $87.46, Total $ 984.46 ... to install the parts below ...
My NB Family...
  #23 (permalink)
Old 03-12-2011, 07:13 PM
D2Beetle's Avatar
NB Yellow Trifecta
OK, one to many surprises today.
Here are the Plugs, Wires and Coil DIY Thread and here is the Front (Forward) O2 Sensor DIY Thread and here is the Rear (Aft) O2 Sensor DIY Thread.
So for some unknown reason I decided the check for any eBahn updates; apparently the online update is not forever, you have buy an "online update" license!
So I will look at everything again tomorrow and next week find out what an online update costs.
  #24 (permalink)
Old 03-15-2011, 03:21 PM
savethebluths.org's Avatar
Super smart senior member
Houston,
Every time I read this threads title I think it says
"Hitler has issues"
  #25 (permalink)
Old 03-15-2011, 04:58 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
"Hitler has issues"
Glad I'm not the only one.
Sent from my DROID2
2000 New Beetle GLS TDI
  #26 (permalink)
Old 03-15-2011, 06:14 PM
IL, USA
Car: Mercedes AMG C55
Make it three. It doesn't help that I call ours Hitlers revenge.
  #27 (permalink)
Old 03-16-2011, 01:38 PM
D2Beetle's Avatar
NB Yellow Trifecta
"Hitler has issues"
LOL
I know, I have the same problem.
Hopefully today I will resolve them all. Despite my NB knowledge I do not have an O2 Sensor tool; had to get one. Also my eBahn DVD has a $65 yearly renewal for software updates.
  #28 (permalink)
Old 03-16-2011, 04:22 PM
IL, USA
I try to get by without special tools if I really don't need them, but this is one that I'm glad I have. On the surface the sensor is just a large hex nut, but when I did my front one I pushed so hard on the breaker bar I raised the car two inches on the suspension before it broke loose.
  #29 (permalink)
Old 03-16-2011, 09:54 PM
D2Beetle's Avatar
NB Yellow Trifecta
Ok, all parts have been installed and it is running smoothly. I will drive to work and back tomorrow for the official road test.
Now to put the Plugs, Wires and Coil DIY together and the Forward O2 Sensor DIY.
  #30 (permalink)
Old 03-16-2011, 10:14 PM
IL, USA
I made a VW spark plug cap puller from a piece of 3/4 inch copper tubing. I found a template to wrap around it and then cut it out with a dremel. Have about a $1 in it. Actually worked great.
  #31 (permalink)
Old 03-18-2011, 11:10 PM
D2Beetle's Avatar
NB Yellow Trifecta
Cool! I however am not that talented.
  #32 (permalink)
Old 12-11-2011, 02:24 PM
D2Beetle's Avatar
NB Yellow Trifecta
Well HiLiter has had this issue since day one, but I just have not done anything about it as it rarely gets gets cold enough here for it to happen ... one of the rear brake calipers freeze when the eBrake is used if it drops into the twenties overnight.
I have read a few posts some time ago about it and if I remember correctly the solution is to replace the caliper. Well it looks like I will not be able to ignore it this time, as it seems both are now freezing up.
  #33 (permalink)
Old 12-11-2011, 07:24 PM
VDubYah's Avatar
Orlando, FL,
I can't believe brake fliud would freeze at 20 degrees. How old is the fluid? Could it have absorbed enough moisture to lower the freezing temperature of the fluid? Or is Crud in the caliper freezing up and hanging up the caliper?
Just food for thought
Hope you figure it out
  #34 (permalink)
Old 12-11-2011, 11:52 PM
D2Beetle's Avatar
NB Yellow Trifecta
The fluid is fine, it has to do with the e-brake connection to the caliper; some how moisture gets in there and it freezes. Releasing the e-brake does not release the brake.
  #35 (permalink)
Old 12-12-2011, 02:54 AM
VDubYah's Avatar
Orlando, FL,
thats German engineering for ya
  #36 (permalink)
Old 12-13-2011, 01:06 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Which side Frank? After replacing my brakes all around after 70K miles, my ps rear pads and rotor were shot. Now, that side is sticking with the parking brake on. I am off for 2 weeks after this week and I'm going to look at it and hopefully just lube it up. It's kind of weird because I had to rebuild the ds rear caliper as the bottom bolt was frozen.
  #37 (permalink)
Old 12-13-2011, 01:43 PM
D2Beetle's Avatar
NB Yellow Trifecta
Not certain which side; I am just going to replace both of them.
To my knowledge if the problem is with the e-brake cable connection, it cannot be fixed; the only option is to replace the caliper.
  #38 (permalink)
Old 01-25-2012, 09:57 PM
D2Beetle's Avatar
NB Yellow Trifecta
OK I have both calipers and will be installing them after I get the wife's clutch issue resolved.
  #39 (permalink)
Old 04-19-2012, 01:35 PM
D2Beetle's Avatar
NB Yellow Trifecta
Well when it rains it pours; well I drove my oldest sons NB yesterday and heard this nasty sound. After a brief investigation it seems that the timing belt tensioner bearings are going out. So I have ordered a Timing Belt kit and hopefully it will be in by Saturday, so I can put it in before something really goes wrong ... (knocks on wood).
  #40 (permalink)
Old 04-19-2012, 04:06 PM
VDubYah's Avatar
Orlando, FL,
Ok, so it is official Murphy hates you. I think you need to get your mojo adjusted. Hopefully TOD can do it.
Sorry to hear about the tensioner.
Another 1.8t with issues turbow8 1.8 Liter Turbo 9 04-10-2009 03:32 PM
ABS Issues Bama 2.0 Liter Gas 4 04-19-2008 11:27 PM
Issues in my '99.. pinktimbs Transmission Talk 1 05-18-2007 03:23 PM
Nbc Having Issues bluebeetle67 New Beetle Convertible 5 11-27-2006 07:28 PM
1.8t issues exzotikbeetle 1.8 Liter Turbo 3 06-22-2006 02:19 AM
