Check engine light flashing - NewBeetle.org Forums
Old 01-18-2010, 06:42 PM
Default Check engine light flashing
My 2003 VW Beetle has a flashing check engine light. The car seems fine when idling but is really sluggish when I press on the gas. It rained so I am thinking this may have something to do with it?? I checked the gas cap and it is tight. We just had him into the shop last month for another check engine light alert....this was for a new water pump, timing belt and coolant sensor. So I hope this isn't something major! He is getting expensive. Any ideas?? Thanks!
Old 01-18-2010, 07:21 PM
Get the car scanned at autozone or an equivalent.
Though I'm pretty sure flashing means to stop driving the car and fix what the problem is. The only time mine came on was for a dead O2 sensor and it just stayed on solid.
Old 01-18-2010, 07:30 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
Wink
Jeez,eh,yeah,don't drive it too much because it may or may not be serious...Take your beast to Autozone,get 'em scanned,if your not certain the seriousness of the situation,let us know wussup,just ask.
Usually a flashing CEL is caused by serious miss fire,detonation,backfire,ect.
Good luck,its prolly not to bad,knock on wood.
Old 01-18-2010, 07:33 PM
yeah, thanks. I am thinking of letting him sit for a day in hopes it is water somewhere that will dry out?? Who knows. If it continues he is going to Autozone, which is a bit of a drive so I hope it isn't serious.
Old 01-18-2010, 09:48 PM
Ayy! Chicky Chicky
Louisville, KY, USA
Car: 2003 VR6 GTI, 2002 Jetta 1.8T, 1988 Cabriolet.
You shouldn't drive it at all with a flashing CEL.
Old 01-18-2010, 11:12 PM
VW Junky
The time between ny last post and now, I had purchased a sweet new craftsman CanOBD2 scanner tool for my b-day tuesday,oh how I'd love to scan your bug right about now.
Turns out I had a misfire myself,cleared it up and has yet to return...
Good luck with your MIL,its not a bad investment to look into on yourself,btw.
Old 01-19-2010, 12:22 AM
Terre Haute, IN, USA
Car: 1999 Beetle TDI, 1990 Audi CQ, 2002 Audi A4 6mtq, 2000 VW Pointer
Flashing CEL is usually caused from seriously misfiring...infact that's all i know of that causes a flashing CEL.
Your ECU retards the timing trying to compensate, that's why it's bogging.
Old 01-19-2010, 12:53 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
well, you did say you had the timing belt done...
timing off a tooth+bad plugs=flash
bad plugs+wires=flash
crossed wires=flash
a flashing cel is caused by a multiple cylinder misfire at the same time.
i wouldn't drive too far, but a few miles ain't gonna kill ya.
Old 01-19-2010, 01:42 PM
So I let him dry out and the CEL is no longer flashing but steady. I will take to get codes scanned at Autozone later today. I am thinking spark plugs got wet?? He now seems 'normal' when idling and gassing...not shuddering like before.
What is ECU?
Old 01-19-2010, 02:06 PM
VW Junky
What is ECU?
Although they might of contributed,they weren't the cause of your orig. problem.
ECU,on-board computer,engine control module,unit,it means the same
Tags
check engine light , flashing
Flashing Check Engine Light buggin99 2.0 Liter Gas 7 06-14-2010 01:22 PM
2001 glx + awp engine swap = check engine light!?! NEED HELP garvitron 1.8 Liter Turbo 7 05-07-2009 12:22 PM
Check Engine Light Flashing Sethkj 1.8 Liter Turbo 7 07-13-2008 04:01 AM
BLUE Light, cold engine, Flashing carkahlua 2.0 Liter Gas 5 09-12-2006 02:26 PM
Why Is My Engine Immobilizer Light Flashing? Bugdoo Questions, Issues, Concerns, or Problems with the New Beetle 4 07-02-2006 11:25 PM
