2000 Beetle Valve Cover Gasket? - NewBeetle.org Forums
Old 03-01-2010, 03:51 PM
Question 2000 Beetle Valve Cover Gasket?
So I saw that I had a very small amount of oil dropping onto the floor of the garage, and I just had a new oil pan installed a few months ago. Took it to the dealer hoping they made a mistake and would fix it for free and they listed the problem as Leaking Valve Cover Gaskets.
Okay thats fine and dandy however they want 320 dollars to fix it. I looked up the price of the gasket itself and thats only 20 bucks. 300 dollars in labor? He said it would take 2 hours.
So I am looking for people who know how to replace a Valve Cover Gasket on a 2.0 2000 VW New Beetle. I would like to know how hard it is to get to the gasket to inspect it myself to make sure the dealer isn't just pulling a problem out of a hat and wanting my credit card #. Also how hard is it to replace the Valve Cover Gaskets in the event that I do see that it is leaking?
Should keep in mind I am very anti car when it comes to fixing things. I opened the hood and cant even find the valve cover. Watched a video on replacing the gasket in a Honda and it didn't look that bad. A bugs engine compartment is so much smaller I don't doubt it would be a hassle.
Old 03-01-2010, 04:47 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
The upper half of the intake will have to come off, that is where the labor is; not to mention the gaskets for it as well. Here is pic of what a 2.0 looks like with the upper intake and valve cover removed.
My NB Family...
Old 03-01-2010, 05:12 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
if it takes longer than an hour to do, i'll hang up my hat.
even on my first time doing one, it only took 45 minutes.
Old 03-01-2010, 05:17 PM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
This is what the whole cylinder head looks like on a 2.0l Aeg..Not sure which engine you have but the concept is similar for all engines in our NB's. #18 is what needs to be replaced.. I have done this job in about an hour..not difficult if you have a repair manual and basic hand tools and knowledge...
Old 03-02-2010, 01:32 AM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
You're sure it's the gasket? My NB had a slow oil leak for months. The dealer diagnosed it as a bad valve cover gasket and quoted me $400. I took it to an independent shop and they said the same thing after they got it on the lift. I finally took it to a VW mechanic and he found the real culprit - cracked oil cap for $25. He followed the trail of oil all the way to the source.
Old 03-03-2010, 11:37 PM
Canadian New Member
No i am not sure....just tryin to help....Hard to be an internet mechanic when you cannot see it for real....Some peoples kid's..???
Old 03-04-2010, 12:04 AM
Pierce County, WA, USA
Car: 2000 GL
The dealership is full of potatos. leaking valve cover gasket. Very likely. However, 2 hours labor on that? BS
I assume their charging you flat rate? Not an hourly charge. That would be 150 an hour.
On flat rate, they say 2 hours and will have it done in 1.
I absolutely "hate" shops that charge a ridiculous labor rate on a flat rate job. 70-90 bux is all I see here.
Take it to another local VW private shop. That job is not that difficult.
Alldata says labor time is 1.6 hours. Mitchell on-demand says 1.7.
not even 2 hours. I am smellin the BS
Old 03-04-2010, 12:33 AM
CoriBug's Avatar
Huh? I wasn't talking to you. If you read the original post he asked about his valve cover gasket.
Old 03-04-2010, 06:04 PM
Canadian New Member
As i said i am trying to help the OP as he or she doe's not know where it is comming from...???? Can you see what he's talking about though the internet??? If you can your better than me...The point being....Trying to save him or her some $ as this is a good DIY project and will save lot's of cash if done by the OP... Instead of the stealer...Save the attitude for someone else....
Old 03-04-2010, 06:29 PM
CoriBug's Avatar
I still don't understand why you're so offended. The OP.said their car has an oil leak. I replied and said that mine also had a small leak and it turned out to be the oil cap. I asked them if they were sure the problem was the gasket and all of sudden you're upset with me. I don't have an attitude but you seem to have one.
For the OP: did you confirm the diagnosis?
Old 03-05-2010, 07:20 PM
Canadian New Member
I was not talkin to you is what offended me......Just tryin to help someone else and i get that kind of a comment....Do have any idea what you are talkin bout.....???????? As said by the OP it was the valve cover gasket as diagnosed by VW.... So the question to the OP is where is the leak....????
Old 03-05-2010, 07:52 PM
noR's Avatar
Administrator
Jackson, MS, USA
Cori wasnt' talking to you either.
both user comments were directed to the OP.
It'll be fine, everyone's trying to help. Everyone has ideas. Let's just show all the ideas all the common occurances, problems, solutions; and then it's the OPs job to sort it out.
noR | me | Phrog
PHROG
Old 03-05-2010, 08:02 PM
Canadian New Member
Thank's Ref....
Old 03-05-2010, 08:45 PM
CoriBug's Avatar
Thank you Ron. Amazing how comments can be taken the wrong way. The OP hasn't replied - I wonder if they went ahead with the repair
Old 03-05-2010, 08:49 PM
noR's Avatar
Administrator
Jackson, MS, USA
it's a shame, it doesn't appear they had much desire or practice to DIY. But it would have been a good one, even for a newbie.
Old 03-07-2010, 09:53 PM
Dakota's Avatar
Owner of Herbert!
Calgary, Alberta, Canada
Car: 98 New Beetle - 02 Dodge Dakota Sport 4X4 Quad Cab
As far as I can see , its not 150 per hour . What I do see not included in this quote is stuff like the upper intake gasket , any shop supplies , taxes , environmental fees , etc . All that stuff adds up quickly!
Old 03-08-2010, 11:57 AM
D2Beetle's Avatar
NB Yellow Trifecta
How about now? #15 and #11 are you only gaskets and #9 is vacuum hose; gaskets are $5-$7 from the dealer and .10 foot for the hose; you'll need 4-5 inches. Shops supplies? one roll of paper towels $1. Taxes? What ever your state charges. Environmental fees? Do it in your garage.
Old 07-24-2010, 02:05 PM
MI, USA
Car: 1998 Beetle GLS
***It says to use sealant on the bearing cap and #1 cylinder....do you use sealant and the gasket ???
***What do you use to clean the surfaces ?
***Can you use sealant in place of the gasket for #11(the smaller intake gasket)
*** Why do you have to replace the hose ?
Old 07-24-2010, 02:52 PM
MI, USA
Took the Vent housing(#3) off,and its cracked inside and the gasket(#5) on top of the valve cover looks worn out....
Is this a dealer only part ??
Old 07-24-2010, 03:14 PM
D2Beetle's Avatar
NB Yellow Trifecta
Bearing cap? Not familiar with that name, need a pic.
Technically you can use "permatex" type sealants just about anywhere, but here is what you need to consider...
1) ... loose sealant material
2) ... get an even displacement of sealant
3) ... can it take the heat and/or pressure
Number one and two are you going to be your biggest problem; having your intake manifold suck any of the sealant in would be disastrous.
Which hose are you referring to?
Valve Cover Gasket leaking in Sparkplug Holes SilverSportNOLA 1.8 Liter Turbo 2 09-19-2011 05:18 PM
Valve cover gasket/are you a mechanic and going to Roswell? CoriBug 1.9 Liter TDI 25 08-04-2009 01:50 AM
leaking valve cover gasket beetlejuice Questions, Issues, Concerns, or Problems with the New Beetle 3 01-10-2008 12:05 AM
Thermostat/Housing/Valve Cover Gasket Replacement tester00003 Questions, Issues, Concerns, or Problems with the New Beetle 1 07-09-2006 02:08 PM
MY New Beetle 2000 2.0 with Perfect Fit cover mezonesxbox Photos: New Beetles 11 05-30-2006 01:19 AM
