my 02 beetle makes a noise at cold start up - NewBeetle.org Forums
Old 03-08-2010, 06:32 PM
spombe's Avatar
Unhappy my 02 beetle makes a noise at cold start up
I noticed recently that my 02 beetle makes a noise like "kazoo" when I start her up cold. I bought her used 5 month ago and never noticed that before. The noise lasts for only a second and then goes away. My last oil change was 800 miles ago, and the oil level now is just above the line where I should add oil again. Other than that, she runs fine. When start up warm, there's no noise. Any ideas?
Old 03-08-2010, 07:07 PM
High pitch? low pitch? Grinding?
I've been getting a noise on cold starts that an almost grind sound. Its something with my starter. Didn't really notice it until it got really really cold here this winter.
Old 03-08-2010, 07:17 PM
spombe's Avatar
It's more like grinding but it's not very harsh. I'm in California and it's not really cold here - -||| Did you replace anything after you noticed that?
Old 03-08-2010, 07:18 PM
oceanjoe89's Avatar
Perry, IA, USA
I'm gonna vote secondary air pump... do some searching on that, and i bet you will find numerous threads and posts about situations similar to yours!
good luck!
Junior (My Car)
Jake (Me)
Old 03-08-2010, 07:19 PM
I haven't. I've read its just something that is a bit dirty. I had started a thread on here about it a bit ago. I'm going to see what happens once the weather gets warmer. If it continues, then I might do something about it. I noticed it about 2 months ago now probably. Its a moderate to high pitched whine/grind. Lasts for about a second, literally.
Edit: Here is the thread I started. Grinding on startup
Old 03-08-2010, 07:35 PM
spombe's Avatar
good luck!
@oceanjoe89, thank u.. I'm not sure, gonna do some research on that. If it is the secondary air pump, i think i'll have to take it to a mechanic ((
Old 03-08-2010, 07:40 PM
spombe's Avatar
Thank you for the link, Smileybug. Seems that mine is having the same problem as yours. The noise happens at the end of startup, yes. This morning I turned it off and on a few times, and it did that every time. After I drove it to school, I tried again, and this time it was all right. Only that it is in the 50s here today- -|| Gonna try it a few times more and will update. Or I'll have it checked up this weekend when I have its back brake replaced
Old 03-08-2010, 08:41 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
good luck!
I second that vote... I need to post a YouTube video of mine and the odd noises they make on a cold start. Something to do Wednesday.
My NB Family...
Old 03-08-2010, 09:25 PM
spombe's Avatar
Yeah that'll be very helpful! Please post the link here once you post the video!
Old 03-08-2010, 09:47 PM
A grinding would be the secondary air pump? I know mine definitely sounds like starter grind...
Old 03-08-2010, 11:36 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
I know both the starter noise and air pump noises well.
The air pump sounds like a little vacuum going under the hood and goes roughly 30 seconds before turning off.
The sticking starter sounds like a low pitched second or so "wrghwhoooo" or something. I would easily guess thats what your hearing. If you say it sounds like a low pitched kazoo
Old 03-09-2010, 05:32 AM
spombe's Avatar
Toad, yes, the noise sounds more like what you describle as the sticking starter. It lasts for just a second so it shouldn't be the air pump.. So does it mean there're problems with the starter? Do I need to do anything? Btw when I started it this afternoon it didn't make that noise. I don't know if it will do it again tmr morning. Gonna try.
Old 03-09-2010, 07:50 AM
Toad's Avatar
Mableton, GA, USA
The rod in the starter needs to be greased or something, i don't know. I had my beetle for 3 years ad it made that sound for a good duration of that time and I didn't do anything about it. It never got better or worse. So i just left it as is.
Old 03-10-2010, 11:36 AM
Its just the starter sticking slightly, happens on most MK4 Golf based cars. You can solve it by either greasing up the armature inside the starter (sometimes cures it), replace the starter, or ignore it until it breaks, most people have this noise for years with no adverse problems.
It usually goes away when the weather is warmer, then reappears when it gets cold again
My advice - ignore it
Our cars:
2006 1.9 TDI PD New Beetle Convertible (UK car)
2007 2.0 New Beetle (UK car)
1958 1200 Beetle (multi show winning car)
Old 03-10-2010, 12:58 PM
kyliak's Avatar
Royal Oak, MI, MI, USA
Car: 99" GLS Bubmle Beetle
hey hey, I just had this fixed on my car you need to have the gears greased on your starter. Don't let them con you into replacing the whole thing though, its a bit of labor but should be a cheap fix.
Old 03-11-2010, 07:11 PM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
3rd vote.. SAI(secondary air injection) at start up is a normal operation. Kinda sound's like a vacuum. The pupose of this pump is to inject filtered air into the exhaust stream to clean-up emissions ON COLD STARTS ONLY. You should not hear this if the car is warm...
Old 03-11-2010, 09:31 PM
D2Beetle's Avatar
NB Yellow Trifecta
Well it was in the 60's and 70's yesterday so the SAP never came on when I started it. I'll have to wait for it to get cooler and try again.
Old 03-11-2010, 10:22 PM
Canadian New Member
Sure rub our noses in it......Lol....Still cold here.....Can't wait for some warm weather here..
Old 03-17-2010, 06:24 PM
spombe's Avatar
Yeah, now it's getting very warm and it isn't making that noise anymore. I guess I'll just leave it. Thank you for your advice.
Old 03-17-2010, 06:27 PM
spombe's Avatar
Hey, thanks! Now it's warmer and the car isn't making that noise anymore. Thank you for your advice! I'll try that when winter comes
Tags
engine , noise , startup
Why does my 06 beetle conv. make a fluttering noise but wont start?? aliciaanne731 New Beetle Convertible 3 11-23-2011 12:27 AM
Cold Start Problems wufpack 2.0 Liter Gas 17 03-01-2010 11:55 PM
Cold Start problem SPIKEVW 2.0 Liter Gas 0 10-19-2009 12:32 AM
Cold start problem..... oldsdroptop 2.0 Liter Gas 0 04-30-2009 01:51 AM
A/C works, but makes grinding noise mrchaotica Questions, Issues, Concerns, or Problems with the New Beetle 10 09-05-2008 04:45 AM
