Thoughts on Zimmerman -vs- Brembo rotors - NewBeetle.org Forums
Old 03-09-2010, 02:14 PM
Pierce County, WA, USA
Car: 2000 GL
Default Thoughts on Zimmerman -vs- Brembo rotors
Its time for new rotors! Quite simply put.
Zimmermans appear to be good quality. We all know of Brembo.
(i assume) In any case, anybody used Zimmerman products?
I ask because they are significantly cheaper, and yet quality appears to be "top-notch".
Anybody rollin this setup?
Also, has anybody converted the stock Beetle spindles, to the Audi TT 288mm spindles?
Old 03-09-2010, 03:21 PM
OH, USA
Car: 03 GTI
Zimmerman's are decent for an average driver. If you are very agressive you might want to spend the $$ for Brembo. Actually, the spindles from any Mk.4 car w/ a 1.8T or VR6 are the same. You can put the larger TT front brakes on for pretty cheap once you have "upgraded" your spindles and calipers. Start hunting the salvage yards.
Old 03-09-2010, 08:45 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Pretty common conversion and quite straightforward.
BTW I would stick to Brembo personally, never heard of or used Zimmerman but that may just mean they use a different brand name in the UK or arenīt over here at all...
Cheers
Simon
Old 03-15-2010, 04:44 PM
vdubbugman53's Avatar
Arvada, CO, USA
i run zimmermans on my race car...with a good pad they do just fine
Old 03-15-2010, 10:03 PM
Car: 2000 GL
Still havent decided yet... the more I do research, the more Zimmermans are drawing my attention.
Old 03-15-2010, 10:54 PM
noR's Avatar
Administrator
Jackson, MS, USA
I tore up some zimmermans using mintex red box pads.
I've since sworn off both. They ate through and did wayy too much damage, way too fast.
noR | me | Phrog
PHROG
Old 03-15-2010, 11:55 PM
giink's Avatar
Pelham, NH, USA
Car: 2000 VW Beetle 2.0L (AEG)
Just replaced rear brake pads, calipers and Zimmerman Rotors... great product and great price! I've had no problems.
New Brembo front brake rotors pcb122 Parts and Accessories 0 03-29-2008 02:51 AM
Brembo brakes? Good for JB?! JuggBug Technical Modifications 34 01-10-2007 10:05 PM
How do these rotors look? Audiophil Miscellaneous Hoo-Ha Archive 6 10-05-2006 04:09 AM
Best Brake Rotors? afroehle 1.8 Liter Turbo 3 01-30-2006 06:53 PM
Brembo Big Brake Kit for 1.8t Beetle 99dub Market Place Archives 0 09-30-2005 08:12 PM
