Help with GFs car. - NewBeetle.org Forums
Old 03-11-2010, 12:53 AM
Default Help with GFs car.
So this is where im at right now.
This is my gfs car
I have no idea about these cars.
she has had the car about 2 years, she has never done any maintenence on it.
The car will start fine, go through first an second fine an then act like it has no power, no matter how much you step on the gas. My father looked at the car and noticed the hose to the brake booster was ripped all up, replaced it.. drove the car around and it did awesome, rode fine, like normal.... but then a few hours later, i go to test drive it again, and its doing the same crap, like it has no power like it doesnt want to drive, ill come to a stop an the idle is acting like it wants to cut off.. im lost? i have no clue... does this sound like a tranny problem maybe? i have no idea. please help. trying to save the girl some money.
Old 03-11-2010, 12:54 AM
Default btw
this is a 1998 beetle. its automatic and its just a reg bug, nonturbo.
Old 03-11-2010, 01:44 AM
Sounds like its in limp mode.
How many miles on it?
Old 03-11-2010, 02:12 AM
Richmond, VA,
Kind of sounds like the way my 2000 acts, but I am sure my problem is the cat (because of the code its throwing).....I have no high end power. Idles perfectly.
Old 03-11-2010, 03:45 AM
Oberlin, KS, USA
Car: 1999 NB GLS
Pull and clean or replace the MAF. You'll need a #20 torx security bit, or you may be able to remove the screws with some pliers. A good parts store should have MAF cleaner on the shelf. My wifes car was doing the same thing, and this seems to have taken care of the problem
Old 03-11-2010, 11:42 AM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
Miles would certainly help. A way to test the MAF is to just unplug it, it's the only electric connection on the air intake (follow the filter back). If it works fine with that disconnected that's likely the culprit.
Phoenix: 2003 Uni-Red New Beetle GLS TDI 132k former-automatic with a 1998 TDI Manual Transmission swap.
Old 03-11-2010, 07:17 PM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
This is my gfs car
First of all...take the car and have it scanned for engine codes(Auto Zone does these for free) Then post back what the scan say's. As all of us can say it's this or that but with a scan you will have a plan of action....Much better than a guess over the net....
Old 03-11-2010, 10:55 PM
Default Mileage & codes thrown
Miles- 126333
About a week or two ago, had the car scanned, codes that poped up were a o2 sensor, iac, and engine coolant temp. sensor. Replaced the engine coolant temp. sensor and the other 2 codes went away.
Old 03-11-2010, 11:02 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Did you try unplugging the MAF (Mass AirFlow Sensor)?
Old 03-11-2010, 11:18 PM
Canadian New Member
Miles- 126333
So everthing is good now then.....Cool...
Old 03-11-2010, 11:52 PM
no, its doing the same crap. just without any codes.
check engine light is on.
Old 03-12-2010, 12:14 AM
Canadian New Member
Codes=Cels(check engine light) These are one and the same...for your info... So as i said have it scaned for CELS and post back what you find as it's hard to diagnose things without a scan...Everyone has an idea but the scan will lead you and us in the right direction...
Old 03-12-2010, 12:22 AM
maybe we arent on the same track, its been scanned.
these are the codes that were thrown.
P0117 - engine coolant temp sensor.
P0132 - o2 sensor
P1582 - I believe this is my problem. I think im on the right track. I found this page, and included is the symptoms to this car.
FU! P1582
Old 03-12-2010, 01:09 AM
Have you scanned the car since the CEL came back on though?
Old 03-12-2010, 07:17 PM
Canadian New Member
This is my point...???? Do the adaptation and post back...????
Old 03-12-2010, 08:11 PM
Pierce County, WA, USA
Car: 2000 GL
The car will drive fine and then at random times will idle funny and try to shut off? or act like it wants to? lack of power?
Have you checked the fuel filter?
Did you check the vaccum lines, EGR valve?
Getting more codes would be good. If there are none, I would look at the fuel components. Fuel filter's love giving these symptoms to their owners. They get clogged and cluttered with crap, and fuel wont flow anymore.
Look at the easy stuff before going onto more complicated items. Usually, the smaller cheaper wear and tear parts are the culprit.
That last code is interesting though...
Old 03-12-2010, 09:11 PM
Canadian New Member
Just to clear the air here... These cars do not have an EGR system... it's called a COMBI valve which brings filtered air from the air box though the SAI (secondary air injection)pump to the COMBI valve to clean up emmision's and help the O2 sensors to heat... Just thought i'd clear this up... The OP needs to do the engine addaptation on VAG-COM...
Old 03-13-2010, 02:03 AM
grr i already did all that. nevermind.
Old 03-13-2010, 03:12 PM
Car: 2000 GL
Really? No EGR? I learn something new everyday. Im still trying to learn everything on these "buggers" ( good pun ).
Thanks for the tip.
Old 03-14-2010, 07:26 PM
Canadian New Member
Thanks for the tip.
No problem...Just be carefull what advise you give...It's better to not give than to give advise if you're not sure....
