Sorry for the long story.
We got the car from my wife's dad. He wrecked it a few years ago. (fell asleep, ran off the road, hit rail road tracks- wiped out the radiator and condenser(sp?)this is all on the to do list, or better yet the re-do list) It sat in his garage until last year when he tried to fix it up to trade it in. The dealer only wanted to give him $1200, so he gave it to us. So I get it and it has a check eng. light. We drove to back from Utah with the light on, it ran fine. I have it scanned and it had three codes (p1128 and I can't find the sheet on the other two- I know, I know) The diagnostic sheets had possible causes on them and the only thing they all had in common was the O2 sensor and the MAF sensor. I bought a scanner and cleared the codes to see if they reset. As soon as I cleared the codes it idled badly and bogged down when I started off. This only lasted for a minute and I wrote it off as driver error. I drove around for most of the next day when the light came on while on the freeway. I double checked the code and all that was there was the P1128. So I changed the upstream O2 sensor and cleared the code again. Big mistake! Now the car has an extremely bad idle, when I press the gas, it bogs down and backfires, then it will rev up. I can’t drive it enough to reset the light. I inspected the vacuum lines for cracks or loose fittings and found none. I did find that the wire connection to the MAF was cracked and the wires looked like they weren’t making a good connection. I replaced that and still no dice. I don’t want to keep throwing parts at this, but the next thing in my sights is the MAF. |
Unplug the MAF and see how she runs. With no MAF the ECU uses an estimate to arrive at the correct settings but the estimate can be better than a failing MAF...if she runs better then clean/replace the MAF, if no change then the problem may be elsewhere.
Cheers Simon |
I did that already and I didn't notice a differance, but I may want to try again after I clear the new pending codes.
OK the new list of pending codes.
P0102- Mass Air Flow Circuit Low Input P0112- Intake Air Temperature Sensor Low Input P0300- Random Misfire Detected P0301- Cylinder 1 Misfire P0303- Cylinder 3 Misfire P0304- Cylinder 4 Misfire Should I clear the codes to continue diagnosing? I think the low input codes were because I ran the engine with the MAF disconnected. |
Have you changed the spark plugs and wires? That could explain the misfires.
here we go...
car wrecked a few years ago, sitting since. bad gas can ruin plugs and injectors. change the plugs/wires, and run a can of seafoam through the tank, intake, and vacuum system. also, the maf is in fact bad if it's recieving a low input. but deifinitely at minimum do the plugs and wires. gotta isolate the easy stuff first. ![]()
Changed the MAF, no light, no peding codes, it's a joy to drive!
The wife took it back. ![]() So I bought some high ratio rockers, a quick shifter and a set of gauges for my aircooled Beetle. ![]() |
| Mass Air Flow Sensor | fxn351@aol.com | 1.9 Liter TDI | 6 | 06-23-2009 07:30 PM |
| Mass Air Flow Sensor | andrzejvan | 1.8 Liter Turbo | 5 | 04-05-2009 01:44 AM |
| how to replace air flow sensor | maximus_d | Technical Modifications | 0 | 05-28-2008 01:06 AM |
| mass air flow sensor? | bobwb | 1.8 Liter Turbo | 14 | 12-17-2007 10:31 PM |
| FS: 2.0 mass air flow sensor | B-Power-B | Market Place Archives | 1 | 10-19-2005 09:15 PM |
