2000 with a 2.0 liter, manual transmission, 130,000 miles.
Just noticed the other day when I turn left *ONLY* at crawling speed there is a loud clunk in the front end on the left side.Have not driven it since because it is significant.The engine and the front left wheel both jump. There are no issues when driving straight, no issues when backing up or turning right. There are also no issues when I turn sharp left and I am coasting, always under load.Replaced the outer CV Joint the other day as I thought there was play, no different, but it seems as though there is play coming from the tierod or rack. Removed the left tieod and it looks not bad but with maybe some slop but not excessive, maybe the play is in the rack? I am thinking maybe Strut Mount but I am unsure on how to tell if they are bad? Going to replace Tierod and look at Motor Mounts this morning? Would anybody out there have any other ideas? ![]() |
A single clunk or a multiple clunk or click sound.
If it is a continuous clunk sound its the CV joint. Loud clunk could be strut mount. Your going to have to have alignment done. Replaicng the strut mount will most likely tweak the caster a little bit. |
Well did the Tie Rod assembly and the Strut Mount and Bearing and no different. Had another person here watching the car as I was turning left and they said they could see movement in the left front tire when the clunk happens. Looks as though the consensus is an inner CV joint on the drivers side. Good thing my wife has lots of money! IF she had loads of money we would buy a new car!
Back to the drawing board. Thanks for your replies. ![]() |
| Noise on the passenger side while turning left? | machX | 2.0 Liter Gas | 3 | 07-30-2009 05:43 PM |
| Suddenly getting loud squeak and loud click... | JEGSSR | Questions, Issues, Concerns, or Problems with the New Beetle | 6 | 12-05-2008 10:07 AM |
| Manual Tranny - Clunk From 1st To 2nd & Won't Go Into Reverse | ThePooper | Transmission Talk | 0 | 06-03-2008 11:15 PM |
| Metallic Clunk | jbthompson | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 05-05-2006 03:07 PM |
| Transaxle noise when turning left | fatbob | 2.0 Liter Gas | 1 | 11-24-2005 10:40 AM |
