Works fine on our '00 NB
![]() Bought an aftermarket HID kit and its fine, luckily the standard NB headlights being Projector type are ok for HID's ![]()
Our cars: 2002, 1.9TDi PD 100 New Beetle (UK car) 2007, 2.0 New Beetle (UK car) 1958 1200 Beetle (multi show winning car) |
I was worried about the DRLs that use less power than when you actually turn on the headlights. So they work ok then....good to know. |
I was pretty close on getting HIDs in my vehicle, but my headlights look like crap.
I want to replace those before putting those in... seems new headlight fixtures arnt cheap. Id do the lens kit myself.. but I know I would ruin them. Im not that patient. wound up getting new bulbs, but I want them brighter still! (seems my halo automotive bulbs arnt that good.. the DRL ones) |
My kit took about 30 minutes to install.... But you need to delete your DRLS as they don't operate properly with HIDS... Simple fix is to bend one of the tabs behind your light switch...no i don't remember which one but could look for ya when you're ready to do the install... Also be aware that 5000k is just slightly blue...the higher the Kelvin (k)number the more blue to purple the light will be... I wanted 5000k but could not get them at the time of purchase so mine are 6000k and look like most OEM HIDS(Slightly blue).....GL...KP...
. Thats what I did.
If you install a relay to work directly off the battery. The relay mod is here somewhere. It will be like a switch the stock low power will turn on relay and give the new aftermarket ballast all the power it needs direct from the battery. I found the mod here. You will not loose the DRL if you do this.
good luck! |
No. You have to disable the DRLs to make the HID kit work. On my vert, I bent the TFL pin down. Some others you have to bend the B pin down, both of which are on the back of the headlight switch. I did it before I installed the kit as to make sure it all disabled properly.
I bought my HIDs here from DDMtuning. I'd recommend you get the slim ballast kit as those ballasts you stick in the hole right behind the headlights. No need to worry about mounting them. I wish i knew that before i bought mine, but mounting them wasn't too hard. Took about 1 hour because i had some trouble getting my headlight buckets out. ![]() BEST $45 i've EVER spent! Also, i disabled my DRLs too. Seriously, why do you NEED them? If people can't see your car coming without headlights during the day, they shouldn't be driving. ![]() |
Instead of deleting the DRLs , another option would be the installtion of the DRL kit available here in Canada that will turn on the headlights whenever the vehicle is on . Its normally used on vehicles that come into Canada from other countries that normally don't have DRLs , but in order to pass the federal safety inspection it must have some sort of DRLs . This kit just turns on the lights when the key is turned on .
| Motorized Headlamps..? | spinjector | 1.8 Liter Turbo | 5 | 10-04-2010 03:29 PM |
| Headlamps keep burning out | eddie1351 | Questions, Issues, Concerns, or Problems with the New Beetle | 16 | 12-31-2009 05:48 PM |
| E-Code Headlamps vs US Spec Headlamps?? | Crazy_MoFo | Technical Modifications | 24 | 04-02-2008 05:10 PM |
| Anyone know how to aim NB bi-xenon headlamps? | bconway | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 08-29-2006 02:46 AM |
| looking for headlamps | jphaviating | Market Place Archives | 0 | 10-20-2005 05:34 PM |
