Horrible knock after Overheating - NewBeetle.org Forums
Old 03-31-2010, 08:27 PM
Mr_n_Mrs_Beetle_Mageedle's Avatar
new member
Viper, KY, USA
Car: 1999 Beetle 2.0
Default Horrible knock after Overheating
I have a 99 2.0 and I've only had it on the road for 4 days. Today after driving about 30 miles it starts overheating and knocking ( worse on acceleration, but does it at idle too). Is my engine messed up? What could be wrong with it?
(o\_|_/o)
Old 03-31-2010, 08:46 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
As the motor heats up the oil thins out. What do you think made the car overheat? Is the fluid level OK? When is started over heating was the coolant light flashing blue or red?
Old 03-31-2010, 08:50 PM
new member
Viper, KY, USA
The light was flashing red. coolant was boiling in the reservoir. My fans are not coming on either. Could the knock just be the thinned oil???
Old 03-31-2010, 08:57 PM
Garage
How many miles on the car? Was your coolant level ok? Did you check your oil level?
oceanjoe89's Avatar
Perry, IA, USA
Couple more questions... how far did you drive with the red light flashing?
does the car still start and run now?
how loud is this knock?
notice any oil in the coolant or vice-versa
fans are a possibility, so is the water pump...
good luck! keep posting!
Junior (My Car)
Jake (Me)
Old 03-31-2010, 08:58 PM
new member
Viper, KY, USA
coolant level was ok this morning and the oil level was ok yesterday, but low today. Coolant all boiled off now.
Old 03-31-2010, 09:00 PM
new member
Viper, KY, USA
I drove the car about 1/2 mile with the red light flashing. The car will still start, but it sounds horrible. I just replaced the water pump about a year ago, and I didn't start driving it until saturday.
Old 03-31-2010, 09:33 PM
70autostick's Avatar
VW Junky
Car: 1999 GLS 2.sl0w
If you got enough oil,cooled down,still knocks...Your boned.
Warped rod? Its possible. Sorry about your mishap,hope everything works out for ya'.
Thermostat stickin' closed??
Old 03-31-2010, 09:37 PM
oceanjoe89's Avatar
Perry, IA, USA
sounds like a rod issue to me, too...
might have roasted the engine, unfortunately. i got lucky when my waterpump went and mine overheated. I stopped immediately, though.
Old 03-31-2010, 09:47 PM
VW Junky
Yep,i pulled over quick,,let her cool down every 3 minutes,made it home with no problems,thankfully.
Hell,rods can come out with the engine in place,other than coin,shoudnt be too huge of an issue.
Old 03-31-2010, 10:06 PM
new member
Viper, KY, USA
I let it cool down and changed the oil (was due a change anyway). It isn't knocking anymore. I found my coolant leak too, the hose off the back of the throttle body popped off. ALSO, my timing belt is very loose. Where is the best place the get a new timing tensioner? I've already got the belt.
Old 03-31-2010, 10:11 PM
middknight1's Avatar
LIVE FREE OR DIE!
San Diego, CA, USA
Car: 1999 GLS Beetle 2.0L 5 speed "Betty"
i just did all the work due to overheating. this is what you are looking at. the knock the the cam bending in its journals since its no longer in line. the head is warped hopefully not cracked. you will need to send it to someone. i sent mine to Frank's TDI by recommendation from users on here. replace all plastic parts i.e. coolant flange, therm houseing and them, maybe even some coolant hoses. i overheated my engine and drove 30 miles overheating. that is all i needed to do. the engine was not cooked. the rings were not cooked no rods bent since there was no contact between the piston and the valve. valves were good and cam was fine. if you keep driving eventually the cam will snap due to the stress then you will have a useless engine unless you replace all the guts top and bottom halves.
you can get an ultimate water pump kit from ECS tuning cost about 200...has water pump timing belt tensioner, therm, g12 coolant, cam seal, crank seal.
"Semper Fortis"
Old 03-31-2010, 10:20 PM
new member
Viper, KY, USA
Will this tensioner work?
Car Part Wholesale - Auto Parts and Accessories Catalog - GMB Timing Belt Tensioner
It doesn't look like the one for my 2.0, but it does say image may vary from actual product.
Old 03-31-2010, 10:26 PM
LIVE FREE OR DIE!
San Diego, CA, USA
the picture is not the tensioner. but like you said image may vary. try germanautoparts.com or ecstuning.com
Old 04-01-2010, 12:02 AM
Garage
So you replaced the water pump but not the timing belt? Or did you replace the belt and not the tensioner?
Old 04-01-2010, 12:16 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
Car: Formally 2001.5 Sport 5speed-- Titan Currently 2005.5 Jetta TDI
I'm curious.... I've never once seen boiling G12 coolant... Not saying it isn't possible, but I've never seen anything of that sort.
Just curious, but are you also using the Correct Coolant? The PINK VW G12 coolant? NOT the green stuff...
Old 04-01-2010, 01:25 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
I've seen it when my coolant flange let go, of course then you loose the system pressure so you are back to the native boiling point....engine was fine afterwards though (once the flange and thermostat were replaced).
Only knocking I've ever heard from an overheated engine is pre-ignition from the hot cylinder head, I've never cooked one long enough to cause bearing damage.
Cheers
Simon
Old 04-01-2010, 04:13 PM
Car: 2000 Beetle 3.2 24v
Why did you drive it for 30 miles overheating?
2000 Cyber Green 3.2 24v
Old 04-01-2010, 04:25 PM
vdubbugman53's Avatar
Arvada, CO, USA
i did that once to my bug....i was so pissed off i was ready to make her melt right there on the highway...i drove 65 miles home on the freeway with that **** blinking at me....crap was boiling.
any way a knock is usually a bearing issue
Old 04-01-2010, 04:27 PM
Arvada, CO, USA
i had g12 boiling like it was pure water
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Ok something I am in horrible need of katwalk Styling Modifications 10 05-06-2008 11:06 AM
Polish Knock knock joke jdesigns Jokes 2 10-28-2007 07:53 AM
Most horrible Bug of all...?? Audiophil Miscellaneous Hoo-Ha Archive 11 06-05-2007 02:14 AM
The official Knock Knock Joke thread Oyveychris Jokes 2 02-04-2006 10:24 PM
knock, knock. who's there? SILVER beetles, that's who! callisto9 Miscellaneous Hoo-Ha Archive 17 12-04-2005 11:46 PM
