Get yourself a Bentley manual if you are going to be doing work DIY. Its well worth the cost.
Bentley Publishers - Repair Manuals and Automotive Books
You can also always check ebay and amazon, etc. |
i super charged my nb and i was looking to put a better clutch in than the oe one and i saw that i can use one from a vr6 is this true
what do you mean by TBH and gear box u mean tranny right |
ok thanks now i cant seem to find a performace clutch for my 2.0 everything i find is oem and i super charged so i thought to upgrade the clutch now this guy at the local part store said he could get mine redone with kevlar any +/- to the kevlar i know itd be better than oem.
We have a few clutch upgrade options available, our Stage 1 Kit uses a larger clutch disc for extra holding power:
Volkswagen New Beetle 2.0 > Drivetrain > Clutch ![]()
http://www.ecstuning.com :: Email: sales@ecstuning.com :: Facebook :: Questions? PM or Email for the quickest response! |
i think you would be lucky to have it hold over 150 hp. to do the clutch you need to get the car high enough off the ground (safely) to get the tranny out from under the car.\ remove battery and tray and air box for plenty of room remove the starter and the ground straps on that. remove shift linkage and unplug speed sensor remove both axles (8mm allen on a 2.0 or at least it was for me) remove remaining bolts holding motor and gearbox together put a jack under gearbox and disconnect motor mount get under car next to jack and get ready to hold a transmission remove jack to let tranny down..its heavy but you should be able to wiggle it loose. eventually it will be on your chest and you will have to wiggle your way out from under it once now that that is out you can see the clutch assembly need a 9mm 12 point socket to get the pressure plate off take that off and then you need a 12mm triple square but and an impact gun to get the FW bold off. if you dont have an impact gun then you need a way to keep the FW from turning as you remove the bolts if you reuse the FW then have it re surfaced if not then clean the new FW off real well with some brake clean then install with new clutch centering tool. getting gear box back in is not really an easy task. set it on a jack and pump it up there and do what you can to get it to slide back on to the motor then just put it all back together first time be prepared to make this a 2 day adventure.
thanks man thats what i was lookin for cause my clutch dont slip when i do the 3rd to 5th test it feels like it when i hammer the pedal down like 40 mph in 2nd at 5k rpms or 60 in 3rd at 5-6k rpms so ima just go with a stage 1 from ecs tuning apparently the stock clutch aint holding so again thanks
We have triple square bits / drivers available here on the website along with photos:
Home Page > Search > Triple Square - ECS Tuning Inc They are used in quite a few places on the Mk5, Mk6 models but they are typically found on flywheel bolts on the older models. |
Ok from what was explained to me from the dealer they said it was an 8 point
Sent from my DROID2
| Having a hellova time with a sparkplug replacment | savethebluths.org | 2.0 Liter Gas | 3 | 10-31-2008 02:37 AM |
| NICE TAN's Replacment | Alan From NYC | Miscellaneous Hoo-Ha Archive | 34 | 10-15-2006 09:03 PM |
| Clutch | AmandaErica88 | 2.0 Liter Gas | 3 | 05-17-2006 03:48 PM |
| Brake pad/rotors replacment in Calgary? | Lunar2002 | The Canada Corner | 3 | 03-09-2006 01:30 PM |
| Glow Plug Replacment | greenflyer | 1.9 Liter TDI | 7 | 11-05-2005 08:33 AM |
